Yeah I'll keep that in the memory bank if I'm ever in your situation.
Clearly states helps to start Diesel engines after bleeding .
It must have been leaking air somewhere before i changed the rail to because its never sounded so good and actually builds up boost easier and takes off, used to be a little sluggy before especially around 2k now just revs and revs lol
Sent from my GT-I9505 using Tapatalk
GQtdauto (28th July 2017)
Yeah I meant to ask you about that , did you replace the fuel filter ? Heard quite a few times that someone had trouble with the running and found a leak at the filter .
main thing is it's going and better than before .
