Results 1 to 6 of 6
Thread: Cargo/boot dimensions
    Jul 2017
    Brisbane
    I'm away from my GU for a few weeks and am looking at designing some drawers for the back. I've seen a few threads with measurements but there seems to be no definitive answer. Was hoping someone could provide these measurements:
    • Rear doors to back of 2nd row seats (cargo depth) - at floor level
    • Rear doors to back of 2nd row seats (cargo depth) - 300mm above floor level
    • Width of left wheel arch
    • Width of right wheel arch
    Feb 2015
    Dartmoor, England
    Hi Taylor
    Be careful about going 300mm high if you're having a fridge with standard sliders sat on top. It's just too high.
    I've just done mine, I'll post some pics later.
    This is a thread that's gonna run. Haha.
    Expert Boinzo's Avatar
    Dec 2015
    Brisbane
    Width between the arches works to 1115mm leaving enough wriggle room. My drawer frame was 1120mm.
    There is a protrusion on the right wheel arch that you need allow for. Around 200mm long and 20mm deep and high.
    And I got it in just. But you will need the small door to open past factory to 90 degrees.
    Depth is 915mm at the top of the 2nd row seats. I worked on 900mm.
    2015 GU ST 3.0CRD Auto Wagon, 2" EFS Lift, 5 x Procomp 16s with MT ATZ P3s, TJM Outback Bar and 12000lb Winch, 80l Sub Tank, Redarc 40A DC-DC with Optima Battery and 180w Solar, ARB Compressor On-board, 3" EXHAUST, Rhino Pioneer Platform and Darche Awning, DIY Drawers to come!
    Jul 2017
    Brisbane
    Thanks for the advice and measurements. So 915mm at the top of the seats, do you know what the depth at floor level is?
    Gold Coast
    "Outback" drawer dimensions (from factory specs) 950 L x 470 W x 220 H. each drawer.
    Of course you can double up height one side, and have the fridge slide either floor level or 220 high.
    These are a good fit in my GU, with small lift out side covers above the wheel wells.
  6. #6
    Feb 2015
    Dartmoor, England
    Here are a few pics of my storage solution.
    I used Euro boxes for my drawers, which are, as it happens exactly Dr Gary's 220mm high!
    We use these a lot over here for general warehousing as they stack and can come with lids. I just wanted to keep things light in the back.
    The fridge slide I made from some old garage shelving for the frame and a pair of 200kg fully extending furniture runners.
  7. The Following User Says Thank You to Daveyboyjunior For This Useful Post:
    Dr Gary (1st August 2017)
