Hey guys I'm about to buy a 16g mamba turbo it comes with oil lines and I will order a manifold. just curious about where the oil lines go and where to get a crossover pipe from 😉
I'd advise buying the 16G with the 6cm bolt-on turbine housing so you can bolt a 3" dump directly to it. That pic is showing the clamp for the V-band turbine outlet.
If you're fitting it to a N/A engine, the oil pressure outlet is a grub screw just above the LH engine mount. Have a search, there are tons of pics around showing the grub screw.
