Page 2 of 6 FirstFirst 1234 ... LastLast
Results 11 to 20 of 54
Thread: Cold weather hiccups
    Legendary dom14's Avatar
    38 Post(s)
    Quote Originally Posted by Throbbinhood View Post
    Nah, it's more that it loses power if I don't warm it up enough before hitting the freeway (freeway is about two minutes from my place). Never have the issue if it's been sitting warming up at home, or if I run a couple of errands in it first.
    Auto choke probably need an adjustment, perhaps turn anti-clockwise a bit to keep the mixture rich bit longer, assuming the issue is mixture getting lean before the engine's warmed up enough.
    Does your backfire(hiccup out of intake/carby)?
    Few more mods on the way
    https://www.panthera.org/
    Cheetah Outreach
  2. #12
    Jul 2014
    6 Post(s)
    Choke is wound all the way off (ie, no choke), so yeah, makes sense I'd have that issue haha.
    Nah no backfiring.
  3. #13
    84 Post(s)
    I have to run the pre-heat in winter or the the carby plays up badly. I run a manual choke and use the hand throttle to bump up the revs to about 1500 RPM. I back off the choke a bit after a couple of minutes. This gets my out onto the main road, and half way into town before its warm enough to run properly.
    @dom14. I was told, in harsh terms, to keep the deflector as it will affect the mixture in some of the cylinders.
  4. The Following User Says Thank You to mudnut For This Useful Post:
    dom14 (4th July 2017)
  5. #14
    38 Post(s)
    Nah no backfiring.
    Take the air cleaner out and see whether the choke flaps are moving after few minutes of cold starting.
    The bimetal electrical choke unit fails more often than we would like to see.
    I guess you remember my choke rebuild threads!
    Cheetah Outreach
  6. #15
    38 Post(s)
    It won't be easy for me to find a one. I'll look around. I guess I can try to panel beat a one out of a piece of pipe and some TIG welding.
    Cheetah Outreach
  7. #16
    Jul 2014
    6 Post(s)
    Nah, I deliberately wound it all the way off. Kept having issues with it, had a trip and was easier to work around having it off and having to let it warm up, than it running like a pig once warm.
    Always intended to fix it, but, time and effort and all that.
  8. #17
    38 Post(s)
    If you wanna drop in I can fix it for ya for free, or alternatively get rid of it and attach a manual cable to it, so you can open and close the choke at will.
    Come to think of it, I think I owe ya a visit, I was talking about dropping in but never did, did I?
    Cheetah Outreach
  9. #18
    84 Post(s)
    Check the choke break diaphragm. It should pull the choke off after just a few minutes.
  10. The Following User Says Thank You to mudnut For This Useful Post:
  11. #19
    38 Post(s)
    Do you know how the choke break diaphragm work? I mean how the diaphragm get the vacuum in it to trigger the choke break after few minutes?
    Cheetah Outreach
  12. #20
    84 Post(s)
    It has a constant vacuum.
