Page 22 of 64 FirstFirst ... 2021222324 ... LastLast
Results 211 to 220 of 635
Thread: Rosscos GQ Rejuvenation
  1. #211
    Legendary GQtdauto's Avatar
    Dec 2016
    Northeast Victoria
    41 Post(s)
    No idea still sussing out which motor LBZ etc and which box , Allison have some problems I hear .
  2. #212
    Rossco, pls check PM
  3. #213
    Cheers Phil, silly tapa. .
    Sent from my SM-T800 using Tapatalk
  4. #214
    1" 70mm body blocks arrived today- much better. And and got some new body mount bolts to go with the new mounts. . . Shiny bits ☺
    Bonnet is ready to be painted, drop that of tomorrow and pick up a couple of doors, then just gotta do the barn doors. .
  5. The Following 5 Users Say Thank You to Rossco For This Useful Post:
    GQtdauto (4th July 2017), MB (5th July 2017), MudRunnerTD (5th July 2017), mudski (5th July 2017), Winnie (5th July 2017)
  6. #215
    Dec 2016
    Northeast Victoria
    41 Post(s)
    Have a feeling mine need changing Rossco , are they buggers to do .
  7. #216
    They're not too bad, probably take half a day i recon. Just gotta watch the rear ones, they're captive in the body and loctited in, if they break free & start spinning need to butcher the floor to get them out. A bit of a pre soak & heat 4 sure to get them out.
  8. The Following User Says Thank You to Rossco For This Useful Post:
  9. #217
    Barn doors are ready, drop those of today and grab the other 2 doors. .
    Yay no more body work to prep, just need to get the guard done again i scratched. 😕
    Also picked up the speedo from patrolapart which they fixed as it started to do the spin up to 180 then go back down randomly thing just before it was off the road. May as well fix it now. . .
    Question; seem to remember someone on here doing a thread on adjusting the reading by turning a variable resistor on the speedo somewhere, just wondering if this will work. . . Don't want to bugger it without knowing what I'm doing. . .
  10. #218
    .......... TPC's Avatar
    63 Post(s)
    @mudnut, is this something you would know about?
  11. #219
    Dec 2016
    Northeast Victoria
    41 Post(s)
    I remember the thread but thought it only fixed the speedo being out not being erratic .
  12. #220
    84 Post(s)
    They prolly replaced the crystal as it is a known problem, that the components legs corrode.
