Page 20 of 48 FirstFirst ... 1819202122 ... LastLast
Results 191 to 200 of 474
Thread: Introducing DavesStuff - Innovative Camping Gear That Works
  1. #191
    Great idea, yes pics please. Also just realised it must go in the corner of the box as the big round pot would not allow it where it near touches the center walls! I think you mean here below is best mate?
    PeeBee (2nd July 2017)
  3. #192
    First time today using the big pot Phil. Decided to not waste last nights Brisket juices and crank up a soup for tonight. Starting off by hot smoking 250 degrees some cheap Beef bones.
    The pot seems great for this, almost like pressure cooking for smokey bone soup stock to follow.
  4. The Following 2 Users Say Thank You to MB For This Useful Post:
    Clunk (2nd July 2017), PeeBee (2nd July 2017)
  5. #193
    In goes last nights leftover 500ml of Brisket juices and another 5.5L of water beef stock from cubes. (Preboiled the water as to not warp the 250degree hot spun steel pot)
    Here's a quick picture of the great lid system with wood chips tray that gets sandwiched underneath the coal top folks.
  6. The Following 4 Users Say Thank You to MB For This Useful Post:
    Bacho86 (3rd July 2017), Clunk (2nd July 2017), gubigfish (2nd July 2017), PeeBee (2nd July 2017)
  7. #194
    And finally in goes 1kg of Spuds, one Turnip, one Leek, 500g bag of Garden Peas and I'll let the coals completely burn out ready warm for dinner tonight!
    Ooh, and the Onions & Garlic went in towards the end of hot smoking the bones earlier.
  8. The Following 3 Users Say Thank You to MB For This Useful Post:
  9. #195
    Loving it Mark! Inspiring stuff.
  10. The Following 2 Users Say Thank You to Winnie For This Useful Post:
    MB (2nd July 2017), PeeBee (2nd July 2017)
  11. #196
    Cheers Chrisso mate! Just for reference on your oven adventures, when the inside box is around 200C a 'full' pot of liquid will boil 'moderately' with around a dozen coals on top. I am now removing a redgum chunk off the top top as it was starting to overboil!
    EDIT: Scrap that above, had to remove 'all' coals now off the top.
    EDIT 2: I'm thinking that the bones have finally reached 100C much like Plasnart's Youtube 'Primitive Technology' bloke uses hot rocks to boil water in clay pots! Have now put a 20mm stick under the lid to let some heat out as it was increasing in boil rate going off its head! (Finally simmering now)
  12. The Following User Says Thank You to MB For This Useful Post:
  13. #197
    198 Post(s)
    OK, couple of pics and a back flip as well!
    The hole in the side of the oven does not work because the head of the thermometer is too heavy and it tips up and would rest against the hot tray, so drill a hole in the rear corner so the probe sits approx 20mm off the wall. the probe length then can be up to 200mm long from memory, so plenty of options regards finding one. Keep the head or dial away from the hot coals, but you can always simply remove the probe when replenishing the coals on top.
    The probe i have used is one from BBQ galore from memory and it has both temps and also cook tenderness bands for different meats. The probe is approx 125mm long and dial 45mm diameter.
    The smaller ones are for direct placement into the meat and have a 25mm head and 50mm prong. I used these for the venison at the camp oven cook off and they worked a treat.
    The hole i have drilled in the side of the oven will be welded up when I get a chance.
    Thanks guys for the continual upgrade advice and suggestions. It all helps to make this even better as a cooking device.DSC01740.JPGDSC01741.JPGDSC01742.JPGDSC01743.JPG
  14. The Following 3 Users Say Thank You to PeeBee For This Useful Post:
    Clunk (2nd July 2017), MB (2nd July 2017), Plasnart (15th November 2017)
  15. #198
    How was it in the end Mark?
  16. #199
    Not too bad at all mate, probably too many Spuds though, went a big thick after mashing.
  17. The Following User Says Thank You to MB For This Useful Post:
    PeeBee (3rd July 2017)
  18. #200
    Ok first time using the oven to roast something....... Nice bit of pork, didn't get the timing right for the potatoes, so didn't quite crisp up enough.
    Will definitely be practising more.... Second photo are left overs for when I get the munchies later
  19. The Following User Says Thank You to Clunk For This Useful Post:
    MB (4th July 2017)
