Page 1 of 3 123 LastLast
Results 1 to 10 of 24
Thread: "How to" GU Bonnet Scoop Removal - a question about the rubber shroud.
    Expert LaughingBeagles's Avatar
    Mar 2015
    Question "How to" GU Bonnet Scoop Removal - a question about the rubber shroud.
    Hi All,
    Just bought a big mouth scoop to replace my standard GU scoop with 6 x 10mm nuts to remove and replace easy as right? It is, except removing the rubber shroud with a steel retaining bracket that is clipped on with plastic clips under the bonnet.
    Before I totally make a mess of it, I thought I would ask if anyone has experience taking it off first. I checked the Y61 Manual section and no luck, searched the forums and tried Professor Google.
    I have no idea how to access the clips and so on; they appear hidden away.
    Looking for a 4WD Club in WA that caters solely for Patrol, Safari and Maverick owners? Click here to HERE to visit the Western Patrol Club. Click HERE for the Beagle Mobile Mods!
    476 Post(s)
    Yeah undo the nuts on the under side, the metal brace comes off, then the rubber, then the scoop from the top. Simple. Hit the bonnet with some polish after the scoop is off too.
    Legendary 4bye4's Avatar
    Aug 2014
    Kingsley WA
    15 Post(s)
    Quote Originally Posted by LaughingBeagles View Post
    Hi All,
    So Pete, where did you get a big mouth scoop. I thought the guy had stopped production?
    Mar 2015
    Quote Originally Posted by 4bye4 View Post
    Hey Tony,
    Fleabay.... Might be he is not the same guy is my thought. Bought this on Ropes' recommendation
    http://www.ebay.com.au/itm/Large-big...53.m2749.l2648
  5. The Following User Says Thank You to LaughingBeagles For This Useful Post:
    4bye4 (27th June 2017)
    476 Post(s)
    Hey Tony,
    bloody hell thats cheap. I paid $550 for the A.R.E Cooling scoop about 4 years ago. Then sold it for $350 a couple of years later.
    Aug 2014
    Kingsley WA
    15 Post(s)
    Hey Tony,
    Just ordered one so if they are no good we can both blame Ropes.
  8. The Following User Says Thank You to 4bye4 For This Useful Post:
    LaughingBeagles (27th June 2017)
  9. #7
    Mar 2015
    Love ya work!
  10. #8
    Mar 2015
    Back on topic, I feel like a bit of a Noob as I cannot for love or money find where the nuts underneath are to take the metal brace off... The foam seal isn't glued over the top of it is it?
  11. #9
    476 Post(s)
    Its been a long time since I have looked at one as mine is different now. This pic might help.
  12. The Following User Says Thank You to mudski For This Useful Post:
    LaughingBeagles (8th July 2017)
  13. #10
    476 Post(s)
    The lower black plate needs to come off first, from memory its longer than the rubber itself. So it may look deceiving.
    See the black plate in the pic, its longer to match the longer hole in the bonnet.
