Page 776 of 1057 FirstFirst ... 774775776777778 ... LastLast
Results 7,751 to 7,760 of 10564
  1. #7751
    Ballarat, Vic
    176 Post(s)
    Had a small awning made by a local bloke out of a larger tent awning I no longer have the tent for. Attached sailtrack to the top of the pod, mounted to a length of 60x60x3mm aluminium angle.
    2.1m x 2m.
    Awning can be used just with the vehicle, but pole eyelets are the same width as those on the awning of the RV3 Oztent so both can be used together using just two poles, giving a double sized awning around 4m x 2.1m (actually tent side is slightly wider at 2.3m).
    I also fitted a digital flow meter for our water supply. Beats taking the cap off the water tank & using a dip stick. Shows water flow whilst in use in litres per minute, plus total amount used, resettable to zero for each tank fill. Filled our tank & then emptied it to find it's useable capacity. Nominally the tank is 160 litres (based on dimensions). Useable capacity was 155 litres. Filled a 9 litre bucket to it's 9l mark & the meter read dead on 9 litres so I'm happy with it's accuracy, which is far better than the meters which have LEDs for 1/4, 1/2, 3/4 & full tank.
    Will even be able to know how much we use for different things. Not totally necessary but when going to 'dry' places it's nice to know how much we have left. A bargain at $41 plus a couple of fittings to add it into the water line. Basically a little tube with an internal impeller & a gauge. Runs on 2xAA batteries.
  2. The Following User Says Thank You to Cuppa For This Useful Post:
    PeeBee (23rd June 2017)
  3. #7752
    198 Post(s)
    Quote Originally Posted by bazzaboy View Post
    Fitted one of these. There are a number of good right-ups on them on Y-tube but got no responses from members on various forums I frequent. 30 day money back if your not happy with it, so I'll give it a go.
    Bazzaboy, what do you use this for?
  4. #7753
    Jul 2015
    Camden NSW
    6 Post(s)
    It's a "plug-in" throttle controller for electronic throttles. Designed to adjust the throttle response. Apparently can eliminate the flat or slow spot throttle action. We'll see.
    https://idriveaustralia.com.au/
  5. The Following User Says Thank You to bazzaboy For This Useful Post:
    PeeBee (25th June 2017)
  6. #7754
    Legendary 4bye4's Avatar
    Aug 2014
    Kingsley WA
    15 Post(s)
    Washed it and cleaned it. Found all the lost tools in the back. Granddaughter helped do the bits I can't reach.
  7. #7755
    Patrol Freak Mc4by's Avatar
    Oct 2016
    Mandurah W.A.
    7 Post(s)
    Washed it.
    How do I get my pics to be larger?
  8. #7756
    Quote Originally Posted by Mc4by View Post
    Washed it.
    When you attach a picture from a URL, un-tick the "Retrieve remote file and reference locally" box below where you enter the URL. When I do that my pics are bigger.
    Gong him Red!!
  9. The Following User Says Thank You to Plasnart For This Useful Post:
    Mc4by (27th June 2017)
  10. #7757
    Oct 2016
    Mandurah W.A.
    7 Post(s)
    I will give that a try, cheers Plasnart
  11. #7758
    Advanced foggs's Avatar
    Jun 2015
    I got one a few weeks back, love it, very responsive.
    2012 CRD 30TD Auto Wagon, 15L/100km | 2" KYB Lift | 3" Exhaust | ECU Remap | HPD boost control | Provent Catch Can | EGR Block | Bullet Snorkel | Dual Battery | Redarc SBI12 | Projecta batt Monitor | Auto Headlights | iDrive Throttle Control | NU3001 7" Android Stereo | Sound Deadening| Reverse Camera | Dashcam | Amp, 12" Sub | 300W Inverter | USB Chargers | Barn Door Gas Strut | Awning | Mods list shrinking
  12. #7759
    Apr 2017
    Anyone know what is would cost to convert a 2.8 td to a 4.2 td in a gu
  13. #7760
    May 2017
    Installed new intercooler after driving around for 2 years with it leaking. Learning a lot of stuff from this site and feeling more confident to tackle project myself. Does anyone know what kind of computer attachment will work on zd30 DI series 3 2004 and give boost?
