Results 21 to 30 of 33
Thread: GU with AutoHubs. Will a LOKKA be a problem?
  1. #21
    476 Post(s)
    Youve lost me a bit but my minds off with the fairies atm..
    My autos have a singke ring in the hub which i had to remove to do bearings.
    I do remember a stepped ring on my old gq, is thats what is needed to locate manual hubs to wheel hub??
    Hmm. The OEM Autos I removed from mine, that ring was part of the auto hub. Like the egg ring was part of the locking hub, if you get what I mean. Yours being newer must be different maybe?
    Now you got me thinking Kallen on the process of installation. I converted mine from OEM Autos to OEM style manuals not that long ago too, and you think I can remember?! But I do know you need both egg and step rings. I think it was this kit I bought...
    http://www.ebay.com.au/itm/Auto-to-M...0AAOSwdpxUUv-u
  2. #22
    Quite possibly is because its newer??
    Ill take a pic when its apart next week
    476 Post(s)
    Yeak farked if I know now. I've barely even thought about my Patrol for months. So many other things happening its been left outside and barely used.
    BigRAWesty (31st May 2017)
  5. #24
    Millicent SA
    hey there the evil twin just because I am a little lazy atm, is there a thread on doing this auto hub mod? cheers Lana
    GU8 2012 Simpson anniversary model, 3" redback exhaust, 2nd primary filter (original secondary), provent 200, Scangauge, engine watchdog, remote uhf dash plug, DRL's, pillarpod with pyro and boost, Titan drawer system, tail light upgrade, more to come
  6. #25
    476 Post(s)
    Quote Originally Posted by shantillylais View Post
    Very simple. Just remove the hub and the first plate you see in the hub, lever the thing out. Done.
  7. #26
    Unafordable
    4 Post(s)
    Just pry the auto clutch part out ==> see the image
    one on the left removed, one on the right still in.
    Really easy job, lock the hub manually first, use M10 Allen key to remove six bolts, pry the bit out, bolt the hub back on, unlock, enjoy!
    To see what is inside of teh auto clutch see below
  8. The Following 3 Users Say Thank You to Rumcajs For This Useful Post:
    Hodge (22nd August 2017), NissanGQ4.2 (20th August 2017), shantillylais (23rd August 2017)
  9. #27
    Millicent SA
    thanks for that, a side job when servicing the wheel bearings next
  10. #28
    177 Post(s)
    Super easy job. Done mine in less than 10 mins I reckon or one Coopers stubby...
    476 Post(s)
    You hub is missing the internal gear...
  12. #30
    177 Post(s)
    Really ?! That's how I found it both sides.
    It looks no different to the one @Rumcajs posted ...
