Results 1 to 10 of 11
Thread: What size bolt?
    Patrol Guru
    Jul 2014
    6 Post(s)
    What size bolt?
    Weird question, but I seem to be missing the bolts that go where the baby seats are meant to clip in. It's a 93 GQ LWB RB30.
    Anyone know what size bolt/thread it's supposed to be? She's going swimming soon and I'd rather not have a fountain coming in through the back.
    Legendary dom14's Avatar
    38 Post(s)
    Sounds like you've been busy mate.
    No, I don't have a clue about the baby seats(I've never been a baby )
    I'm sure few blokes with toddlers or who used to have babies before they outgrew them know the exact answer.
    P.S. I'm sure baby's thriving at super fast growth phase and walking around the house by now.
    Few more mods on the way
    https://www.panthera.org/
    Cheetah Outreach
    Aug 2010
    adelaide
    any place that sells baby seats will have the bolt as an extra or just put a bung in it ar cork of tape
    OH LEATHER IS NICE
    84 Post(s)
    I just use a bit of sikaflex to seal the hole. I leave a few threads clean so I can just screw in the bolt if the anchor points need to be used. After the deep river crossings a few years ago, when I had to lift the carpet, I found a more holes than I could poke a stick at. I spent a long time sealing them and the edges of all the plastic screw inserts.
    I even glued some rubber discs over the holes in the top of the sill panels and up the pillars. I also used some small food containers as junction boxes to seal off the loom plugs under the front passenger seat and also the wiring and relays used on the air compressor under the rear passenger seat.
  5. #5
    IT should be either 10mm v 1.25 pitch or 12mm x 1.25 pitch, you can determine the length
  6. The Following User Says Thank You to threedogs For This Useful Post:
    Col.T (30th May 2017)
    Patrol Guru
    Jul 2014
    6 Post(s)
    Yeah mate, always something going on in this crazy life! Yeah, the young fella is growing too quick! Almost walking.. Time flies!
  8. The Following User Says Thank You to Throbbinhood For This Useful Post:
    dom14 (30th May 2017)
    Patrol Guru
    Jul 2014
    6 Post(s)
    Quote Originally Posted by my third 256 View Post
    Good thinking cheers mate
  10. #8
    Patrol Guru
    Jul 2014
    6 Post(s)
    Yeah I was thinking that, but figure I need the bolt anyway if I decide to move the seat or when number two comes along. I like your thoughts on the wiring/food containers etc. She's normally fairly water tight, at least for what I've done in her, but saw the bolt missing so figured I'd sort it out.
  11. #9
    Patrol Guru
    Jul 2014
    6 Post(s)
    Absolute gun mate, thankyou!
  12. #10
    Advanced abw's Avatar
    Jul 2015
    Sydney, NSW
    Mines a GU, but I needed some longer bolts in the back, including the baby seat anchors. I can't remember the size but after visiting a nut/bolt supplier, he found a strange mix of metric fine thread and UNF (American fine thread). Not sure what Mr Nissan was thinking?
    Andrew
    GU3 Patrol, TB48, 33" muddies. front E-locker. 4.11 diff gears. 2.2 metre steel rack. Awning. Steel rear bar. Safari Snorkel. ARB side steps and brush rails. ARB Deluxe bull bar. Winch. 2" lift.
