Page 771 of 1057 FirstFirst ... 769770771772773 ... LastLast
Results 7,701 to 7,710 of 10564
  1. #7701
    198 Post(s)
    Built a frig temp controller after failing to find one to buy, and it even works! Stuffed around with Pto pump hoses but still not installed due to wrong parts supply, dodged the wife and the ever present "to do list".
  2. The Following User Says Thank You to PeeBee For This Useful Post:
    MB (27th May 2017)
  3. #7702
    Expert Yeti's Beast's Avatar
    Aug 2016
    Jimboomba
    4 Post(s)
    How did you make your controller?
    I once read somewhere that if your Waeco fridge controller throws in the towel, then modify your fridge with one of these
    https://www.ebay.com.au/itm/271956087435
  4. The Following User Says Thank You to Yeti's Beast For This Useful Post:
    MB (28th May 2017)
  5. #7703
    Had a ripper day too finally. No work, 14+ hours of me and me Trol time.
    Strengthened the hubs to cope with front lockers. Strengthened the arse end with a new/better panhard. Beefed up the Drag Link. Installed a first line of defence cheaper than I could buy the steel for. Tie Rod received an upgrade too.
    Working means to an end :-)
  6. The Following 4 Users Say Thank You to MB For This Useful Post:
    Bacho86 (28th May 2017), Clunk (28th May 2017), Rossco (28th May 2017), Touses (28th May 2017)
  7. #7704
    Nice work markie.
    That reminds I've still got a adjustable draglink to fit thanks to Mudski.
  8. The Following 2 Users Say Thank You to jay see For This Useful Post:
    MB (28th May 2017), PeeBee (28th May 2017)
  9. #7705
    198 Post(s)
    Finally stripped out my 3 gal alloy air tank, have a mate who will test it for me so thats peace of mind.
    Ive been running this tank since about 1995. , it cant rust so thats good but my mate will do all the tests neccessary
    so I'll know its safe. Originally I filled it via a $650 Big Balls 3/4hp compressor, but todays "Thumper" would out do it I think.
    Along with another tank, dont know if I'll use it yet or not will run air tools, air horn and a front Pro-locker.
    I think I have enough room to squeeeeeeze it underneath. 1995 they were only $40 from a place in Brisbane
    doing street car suspension, My side tarp for my awning also arrived looks weatherproof to my eye.
    Nearly time to go and get lost somewhere, .
    Thanks for the 'jog' TD, as I lave a 4l reservoir and think I will use it to increase the holding capacity of oil in my hydraulic winch, since it's 100mm dia x 500mm long, should be able to squeeze it in somewhere, and it's stainless ax well.
  10. #7706
    Awsome Markie, she's really turning into a beast now. Is the winch up & running yet? ?
  11. The Following User Says Thank You to Rossco For This Useful Post:
    MB (28th May 2017)
  12. #7707
    Whoah full on Mark and ready for a nice test trip!
    It's a bloody serious work/play best of both worlds rig you've got now.
  13. The Following User Says Thank You to Winnie For This Useful Post:
    MB (28th May 2017)
  14. #7708
    Patrol Freak Bacho86's Avatar
    Mar 2011
    14 Post(s)
    What did you do to your Patrol today!
    I was going to ask the same question, looks like the winch drum is still empty?
  15. The Following User Says Thank You to Bacho86 For This Useful Post:
    MB (28th May 2017)
  16. #7709
    Nearly there......:-)
  17. The Following User Says Thank You to MB For This Useful Post:
  18. #7710
    Got the freespool working now too? Keen to see how the Iskra motor goes Mark!
  19. The Following 2 Users Say Thank You to Winnie For This Useful Post:
    MB (28th May 2017), Rossco (28th May 2017)
