Results 11 to 20 of 38
Thread: UHF radio
    Hardcore belzi82's Avatar
    Jul 2011
    After getting the bullbar it did turn on but now it doesn't
  2. The Following User Says Thank You to belzi82 For This Useful Post:
    GQtdauto (12th May 2017)
  3. #12
    Legendary GQtdauto's Avatar
    Dec 2016
    Northeast Victoria
    41 Post(s)
    Ahh so it doesn't turn on , have you checked that the main power in wire is live at the back of the unit , and the earth wire is grounded properly ? I guess you have replaced the cracked fuse but was it a known good fuse that you replaced it with .
    If all the above check out it means unfortunately the unit might have survived the knock you gave it .
  4. #13
    Jul 2011
    How do I check that the wire is live??
  5. The Following User Says Thank You to belzi82 For This Useful Post:
  6. #14
    Jul 2011
    Sorry, I dont really lnow much but I am trying!!
  7. The Following User Says Thank You to belzi82 For This Useful Post:
  8. #15
    Dec 2016
    Northeast Victoria
    41 Post(s)
    Best , cheapest and easiest way is with a cheap 12 volt test light , sort of like a screwdriver with a wire hanging off the handle end , should have an alligator clip on the end of the wire .
    These cost around ten bucks for cheap ones , the alligator clip goes onto something metal that's earthed , the screwdriver tip should be pointed and needle sharp , this end you just push into the positive wire at the back of the radio .
    Usually a red wire and the earth is usually a black wire .
    You need to work out if the radio is wired up through accessories or direct , ie key on acc to work or live all the time .
    Test the tester on the battery first to make sure it works and make sure whatever you connect the alligator clip is connected to a good earth , easy if you have a multi meter .
    When I say push the probe into the wire at the back of the radio I mean 25mm to 50 mm from the unit , don't push it into the unit where the wire comes out .
  9. #16
    .......... TPC's Avatar
    63 Post(s)
    Buy yourself a multimeter, they are cheap these days.
    Then test where you have lost the voltage, would be happy to talk you through it.
    https://www.jaycar.com.au/low-cost-d...r-dmm/p/QM1500
  10. The Following User Says Thank You to TPC For This Useful Post:
  11. #17
    Dec 2016
    Northeast Victoria
    41 Post(s)
    Hey kudos for giving it a go and no one knows how to do it until they're shown or told how to do it , for some of us this is simple but if you've never used a tester before not so simple .
    I recently wired up some mirrors and the metal plate I put the alligator clip on was not earthed , I spent half an hour and plenty swear words before I dragged out the multi meter and checked that the earth was no good .
  12. #18
    Dec 2016
    Northeast Victoria
    41 Post(s)
    Thanks TPC you're an elec guru I believe .
  13. #19
    Jul 2011
    Hi TPC,
    I bought a multimeter and tested the coax cable and it has power. I got nervous with checking the DC power and so havent done it. I googled how to and got some scary answers. Can you please help me??
  14. #20
    Dec 2016
    Northeast Victoria
    41 Post(s)
    While your waiting for TPC , the back of the uhf unit should have a red wire (positive) and a black wire ( negative ) , the positive wire normally is fused if you can see the fuse disconnect and try testing here .
