Page 760 of 1057 FirstFirst ... 758759760761762 ... LastLast
Results 7,591 to 7,600 of 10561
  1. #7591
    176 Post(s)
    Just finished fitting the steps / sliders. Had to cut the front finishing bracket shorter as it was fouling with the front flares. So waiting for paint to try and re-fit.
    Very solid units though. Mounting system on the RHS chassis was interesting to get around the fuel lines, but got there in the end.
  2. The Following 5 Users Say Thank You to Hodge For This Useful Post:
    BigRAWesty (6th May 2017), GQtdauto (6th May 2017), MB (6th May 2017), PeeBee (6th May 2017), TPC (6th May 2017)
  3. #7592
    .......... TPC's Avatar
    63 Post(s)
    After thinking about it mate we all have different heights..
    So rack is 150mm on top of gutters..
    Do you have bigger tyres, what size do you have?
  4. #7593
    31 tyres and short 2" lift..
    63 Post(s)
    Should be about the same as me then, I have 2" lift and 265/75/16 tyres.
  6. The Following User Says Thank You to TPC For This Useful Post:
  7. #7595
    Legendary GQtdauto's Avatar
    Dec 2016
    Northeast Victoria
    41 Post(s)
    Finally have fitted the temp sensor to the banjo bolt on the GQ , lucked out my nephew had an 1/8 npt tap set and my brother drilled and tapped it for me .
    Once I had the gauge working it was off for a test drive to see what temps mine sit at and on the flat about 80 up an incline pushing it about 91 which is also what I get when idling .
    Getting the oil changed hopefully Wednesday but want to go for a run tomorrow from cold so I can compare the temps with 4th overdrive locked out .
    Then when I've finished packing the camper for our corner country trip I'm going to see what the temps are with OD off and with OD on but 4th locked out .
  8. The Following User Says Thank You to GQtdauto For This Useful Post:
    MB (8th May 2017)
  9. #7596
    Oct 2010
    Old Bar, NSW
    I didn't do it, and it's not finished but getting a replacement turbo and fancy airbox done.
    Finally found a bloke who knows his Nissans and lives near to us. There is a good bloke in Forster but that's a PITA to drop the car off etc.
    So tomorrow I should have it back and hopefully running better.
    I have known the turbo wasn't right for a couple of years but couldn't part with the coin. Now we are buying a caravan it is probably wise to get it fixed.
    Macca
  10. The Following User Says Thank You to macca For This Useful Post:
    GQtdauto (8th May 2017)
  11. #7597
    May 2017
    went to the shop today and me bloody window didnt go back up so went and bought and installed a new window regulator. working like a charm again
  12. #7598
    Hardcore jack's Avatar
    Ballarat Area
    25 Post(s)
    A caravan, I must have missed something. Planning on comfort or an extended lap Macca?
    Jack
    2024 Isuzu MUX
  13. #7599
    Oct 2010
    Old Bar, NSW
    Quote Originally Posted by Apollofish View Post
    G'day mate, 12 month lap looking for work along the way, if we like it we might not be back for longer
    Macca
  14. The Following User Says Thank You to macca For This Useful Post:
    jack (9th May 2017)
  15. #7600
    Dec 2016
    Northeast Victoria
    41 Post(s)
    Enjoy it Macca .
  16. The Following User Says Thank You to GQtdauto For This Useful Post:
    macca (8th May 2017)
