Results 1 to 6 of 6
Thread: indicators and hazards playing up
    May 2017
    cranbourne, vic
    hi my name is col, , just started up my 1998 gu 4500 patrol this morning and the hazard lights started comin on and off at random and the indicators would work for a few second and then change to blinking hazards they are all over the shop haha, does that sound like a relay switch fault and if so where the hell is it and how easy is it to get too any advice would be very much appreciated
    cheers col
    Feb 2012
    Camden, NSW
    I would say a problem with the hazard switch, either that or you just don't use the indicators and pretend you drive a BMW.
  3. The Following User Says Thank You to Turtle_au For This Useful Post:
    GQtdauto (6th May 2017)
    Banned
    Apr 2011
    Greenbank QLD
    25 Post(s)
    Try removing the hazard light fuse (it’s in the fusebox under the bonnet) and see if it still plays up.
  5. The Following User Says Thank You to Yendor For This Useful Post:
    the evil twin (7th May 2017)
    Wot he said ^^^
    Eliminate the hazard control circuits first and if the problem is still there it can be anything from grotty trailer plug, wiring shorts, indicator earths etc,
    Feb 2012
    Camden, NSW
    Could still be the hazard switch, bridging the left and right indicators.
    Quote Originally Posted by Turtle_au View Post
    All things are possible but pretty unlikely.
    Pulling the fuse takes a couple of seconds and will 99.9% eliminate the Hazard Relay so therefore the Hazards can't "come on and off at random" as OP mentioned.
    If the hazards 'appear' to activate only when the indicators are on then it would be a bit higher on the 'possibles' list altho that symptom is maybe 50% or more a damaged/corroded trailer plug or harness
    But, I agree, it could be lots of weird faults... or even other systems IE theft alarms, remote locking, prev owner 1/2 rrsed mods, etc,
    It just pays to eliminate the easy stuff first
