Page 68 of 136 FirstFirst ... 6667686970 ... LastLast
Results 671 to 680 of 1356
Thread: All Things Chev
  1. #671
    May 2011
    7 Post(s)
    Can we all be friends now fellas :-) @ Rainsey Graham mate, how's that Manometer going? You are a busy man I know sorry mate, stay the cause though in good time ;-)
    Hey sorry for taking so long to get back to you. Ive been madly catching up on my home renovating needs since we have finally ( touch wood) got some clear weather. Got a 4 days away up coming weekend with the missus for our wedding anniversary so definitely won't be using it there...
    Weather holding, I'll get back into the pressure measurements week after.
    Stay tuned.
    Sent from my iPad using Tapatalk HD
  2. The Following 2 Users Say Thank You to rainsey For This Useful Post:
    MB (19th April 2017), PeeBee (19th April 2017)
  3. #672
    483 Post(s)
    No stress mate and congratulations on another good year, Happy Anniversary you two!
  4. The Following User Says Thank You to MB For This Useful Post:
    rainsey (19th April 2017)
  5. #673
    Apr 2013
    Upper Ferntree Gully
    22 Post(s)
    Hi MB,
    From our discussions on Hi output alternators.
    this is the web site I was referring to.
    http://www.nationsautoelectric.com/index.html
    cheers
    by the way, great donk party
  6. The Following User Says Thank You to poindexter For This Useful Post:
    MB (1st May 2017)
  7. #674
    That reminds me Mark, if you want that TD42 alternator it's all yours. Doing a shed clear out soon so would be good to get rid of it to be honest
  8. The Following User Says Thank You to Winnie For This Useful Post:
    MB (1st May 2017)
  9. #675
    483 Post(s)
    Quote Originally Posted by poindexter View Post
    Hi MB, From our discussions on Hi output alternators. this is the web site I was referring to. http://www.nationsautoelectric.com/index.html cheers by the way, great donk party
    Thank you very much Ralph mate, appreciated!!
  10. #676
    483 Post(s)
    That reminds me Mark, if you want that TD42 alternator it's all yours. Doing a shed clear out soon so would be good to get rid of it to be honest Sent from my SM-G935F using Tapatalk
    Thank you too Chrisso mate, great folks allofya ;-) !
  11. #677
    483 Post(s)
    Navi's video below may help someone out there for 6.5/Trol/Manual-5Stock ratio outa the mountains test, 2,500Rpm/110kmph ;-) https://youtu.be/pdWUAP6vj7M
  12. The Following User Says Thank You to MB For This Useful Post:
    PeeBee (8th May 2017)
  13. #678
    My BD supplied aftermarket alternator/vacuum pump died on the trip home from the donk party, after a mammoth 2496klm ex new fit net. Looks like the insulation has broken down with a lot of brown/black dust blown out the rear of the casing. BD are sending over a replacement but it's the same make, so might have to look at alternatives, such as stock Nissan in future.
  14. The Following User Says Thank You to PeeBee For This Useful Post:
    MB (9th May 2017)
  15. #679
    483 Post(s)
    Think I might have found my dream alternator gents and bulletproof too they reckon :-)!
    http://www.delcoremy.com/getmedia/37...-6-16.pdf.aspx
    215amps with 121amps at idle.
    It is bulky but measured it up this morning and in theory should just fit drivers side behind the power steering reservoir with a 200mm supported extension shaft to pickup the existing Mitsubishi alternator V belt inline. 121amps at idle should power the 6hp Warn/Mahle motor no sweat :-)
  16. #680
    I thought I was the only one setting myself next to impossible tasks! Good luck with this one Mark, the brackets are going to be a head twist, especially mounted off the engine and with the shaft extension. Make sure you use self aligning bearings/pillow blocks i reckon and these need to take the belt tension, so the alternator shaft doesn't see the tension load at all. I look forward to your adventure!!!! I am guessing the config is something like pulley, then a pair of spaced pillow blocks on a plate, shaft coupled to the alternator, would probably go for a coupling that allows for minor misalignment.
  17. The Following 2 Users Say Thank You to PeeBee For This Useful Post:
    MB (13th May 2017), Rossco (13th May 2017)
