Results 1 to 5 of 5
Thread: Scan gauge
    Patrol God Sir Roofy's Avatar
    TRAFALGAR VIC
    35 Post(s)
    Scan gauge
    Morning to all you auto techs ive got a 02 3l DI wagon and wanting to get a scan gauge to read temps ect
    what would be the best one to get if any
    is the DI an OBD11 or something else ?
    dont you need nissan consult, not sure it will work with the ob2 port on a Di
    TRAFALGAR VIC
    35 Post(s)
    Don't know John that's why I'm asking don't want anything that you have to
    plug into a computer just plug and play I hope
    Feb 2012
    Camden, NSW
    I have 02 zd30 DI in an elgrand. Has obd2 socket but uses consult diagnostics.
    I use a bluetooth scanner and a Samsung tablet running NDS1 app. Can do codes, display realtime data, and can log the values as well.
    http://www.buyobd.com/index.php?main...&products_id=2
  5. The Following User Says Thank You to Turtle_au For This Useful Post:
    Sir Roofy (18th April 2017)
    @Sir Roofy I take it you dont want to run any more gauges,
    my water temp was easy as to install , by cutting
    top hose and using a billet sender adaptor
    Here's my ecu-talk ,,,,its tells me water temps only
    @65 degrees,,,,,,,, reasonably easy to read with old eyes
