Page 750 of 1057 FirstFirst ... 748749750751752 ... LastLast
Results 7,491 to 7,500 of 10565
  1. #7491
    Legendary GQtdauto's Avatar
    Dec 2016
    Northeast Victoria
    41 Post(s)
    Finished the false floor to the rear of GQ .
  2. The Following 2 Users Say Thank You to GQtdauto For This Useful Post:
    Clunk (14th April 2017), MB (14th April 2017)
  3. #7492
    how are you going to incorperate some tie down points.
    Looks good a bit of storage underneath too nice one
  4. #7493
    Took the roof rack off for the first time, looks heaps better without it. Didn't realise how bloody heavy they are! Then took it for a little local drive, looking for good firewood spots.
  5. The Following 5 Users Say Thank You to Winnie For This Useful Post:
    Clunk (14th April 2017), GQtdauto (14th April 2017), MB (14th April 2017), Rossco (14th April 2017), threedogs (14th April 2017)
  6. #7494
    Dec 2016
    Northeast Victoria
    41 Post(s)
    Storage underneath is minimal , I have to get one of those portable twin tub washing machines in and out at some point so just needed a flat surface , otherwise I would have made enough room for pull out draws etc .
  7. #7495
    Dec 2016
    Northeast Victoria
    41 Post(s)
    As for tie down points I've marked where the steel is underneath so I can use that for strength, need a few that's for sure .
  8. #7496
    Finally finished the PTO - Hydraulic pump bracket, fully installed and tightish on the exhaust (20mm clearance), but a couple of wraps of insulating blanket on the exhaust should resolve. Cut the floor for the actuator to the RH side of the gear stick, installed the actuator lever assy - another fiddly job with a Dremmel to cut the floor out. Final tasks are to get new hoses made for the system, seal the hole into the cabin for the actuator, and work out how to run the actuator cable because the PTO is upside down.
  9. The Following 3 Users Say Thank You to PeeBee For This Useful Post:
  10. #7497
    Dec 2016
    Northeast Victoria
    41 Post(s)
    Used to go out and fill up the rear floor and cargo area with wood , bit rough I suppose but can't do that anymore .
  11. #7498
    Patrol Guru firm351's Avatar
    Jun 2013
    Mundijong, WA
    4 Post(s)
    Replaced the dodgy cig lighter sockets i had in the cargo area with these babys.
  12. The Following 6 Users Say Thank You to firm351 For This Useful Post:
    Clunk (14th April 2017), GQtdauto (14th April 2017), juzzs8 (16th April 2017), MB (15th April 2017), PeeBee (15th April 2017), threedogs (15th April 2017)
  13. #7499
    you could drill holes right through everything and use some eye nuts here and there.
    Use some wide mudguard or penny washers to spread the load some what......lol
    M8 would be sufficient I reckon
  14. #7500
    Dec 2016
    Northeast Victoria
    41 Post(s)
    Thanks TD wasn't exactly sure what to do with the tie downs but need to work out what's going first , at the moment it's just the washing machine and a blow mould table , perhaps I can stock up on beer for the rest of the room .
  15. The Following 2 Users Say Thank You to GQtdauto For This Useful Post:
    threedogs (15th April 2017), Winnie (15th April 2017)
