Page 366 of 570 FirstFirst ... 364365366367368 ... LastLast
Results 3,651 to 3,660 of 5693
  1. #3651
    I brought one of the wireless remotes years ago but was told to avoid it
    especially if a tricky situation arises, I have a winch isolation switch
    inside on the centre facia next to a winch in/out switch. Yet to wire it all up.
    My son is an auto elec but thats not going to happen now eh GRrrrrrrrrr
    In a perfect world a 3 battery set up would be nice with 2 x crankers for the winch
    and a DC for the AUX. I had a 3 battery system in my other 4x4 but had no winch
    just two lockers ARB and a Pro-locker up front best set up ever. Not sure what I want to do in the future
    E-lockers are expensive IMO. I have an on board tank and motor again yet to be wired. Plus need to rip
    the 3 gallon tank out of the other 4x4,,,so many jobs,,, How often do you come to town????
  2. #3652
    82 Post(s)
    They wireless remote has been perfect, especially since I use the winch to help with moving large fallen limbs and the like.
  3. #3653
    Thats fine but if youre in a tricky spot where inch by inch is required might not work then
  4. #3654
    82 Post(s)
    The winch came with a wired controller as well.
  5. #3655
    Not yet but who has used one for day trips.
    http://www.supercheapauto.com.au/Pro...ew-list-anchor
    I know it's not a fridge...
  6. #3656
    Stick a frozen ice block in there as well, they work ok to keep things cooler.
    Picked up one of these below for $10 from a garage sale about 5 years ago, apparently wasn't working but worked fine when I plugged it in at home. Still works now after 6 years. Just don't get warm things nice n cold like a fridge, but if you get your stuff nice n cold before loading it up, should stay cool all day
    http://www.bcf.com.au/Product/Waeco-...5-Litre/127958
  7. The Following User Says Thank You to Clunk For This Useful Post:
    jay see (15th April 2017)
  8. #3657
    Anyone looking for a cheap ice box?
    http://www.evakool.com/iceboxes/icem...elene-iceboxes
  9. #3658
    http://www.allfourx4.com.au/epages/s...on=ViewProduct
    So fed up with the Warn winch I have now, every time I want to use it, it fails! That's 2 Warns kark it in 12 years, for what they charge I was hoping for a better service life.
    Snigging firewood logs Tuesday and it died again aarrrgggh.
    The brushes get stuck in the slides they are located in and as the motor is not solidly attached to the winch it moves around and pushes the little buggers away from the commutator. This is the 6th time I've tried to fix this.
    So a 12000lb fits, up from 9500lb and hopefully ticks the boxes. About half the price of a Warn too.
    Yo Macca here's a reply from Warn industries USA,,,,quote I have seen this occur in a couple of winches, the "brush box" corrodes around the bush and the brush becomes stuck. I have seen our service tech's revive an old motor that had this issue.
    I did the same thing with a motor a friend sent me to look at. We freed up the bushes using WD40, and once loose cleaned everything up, then applied
    dielectric grease to the brushes to coat the inside of the brush box to prevent corrosion forming again, the motor worked fine and is still working after
    a couple of years.
    I know this does not sound like something that should be required to do to a winch motor , but it seems to me that the brush clearance inside the brush box is very tight to begin with on some motors, so there is no room for corrosiononce it begins. I believe the tolerance spec is not adhered to by our supplier as closely as it should.
    As already mentioned I will log this issue in our system for further review. un quote
    Best regards
    Steve Schoenfelder
    Warn Industries USA
  10. #3659
    That was the bloke i spoke to to gey my stickers (Steve). He was great, very good service sent out a sticker kit for free ☺ . .
  11. #3660
    Went out an brought one.
