Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
Thread: Newbie with a Nissan 2000 ST Fourbie
    Patrol Freak Dark 1's Avatar
    Sep 2010
    Mundaring, Perth
    Welcome mate, have a poke around & join in when your ready.
    Watch out there's a Poo "Yota" lurking in the shadows !
  2. #12
    Legendary timbar's Avatar
    Feb 2011
    perth
    G'day mate - welcome aboard join in and have fun mate plenty to do see and if u have any problems just ask and im sure u will get an answer ENJOY and WELCOME
    Tim
    1989 GQ LPG / PET TB42 LWB WAGON 4'LIFT 33's
    WELCOME TO THE MUD PITT WE DRIVE NISSAN PATROLS
  3. #13
    Patrol God Bob's Avatar
    Oct 2010
    Pakenham
    47 Post(s)
    Welcome Steve . Join in the conversations and enjoy
  4. #14
    Apr 2011
    Gladstone QLD
    Suggestion
    Hi
    I'm brand new to this forum but noticed your problem Steve whilst reading some of the posts. I had same issue with my 2004 3litre turbo diesel - the problem was the MAF sensor as noted further down by someone else. Basically it was serviced and a month or so later no power. Took it back in and Nissan charged several hundred to change the MAF (master air flow sensor - i think) and all good again. The recycle air (some minute oil trace in it) thru the air cleaner and back over the sensor is possible cause. If MAF dont read correctly (its likely to be a simply pitot tube or thermal mass inferred measurement) then the fuel add and therefore combustion is incorrect affecting power significantly.
    Regards Freddo
  5. #15
    MAF is Mass Air Flow sensor so you were close, and you are correct. The MAF sensor can be contaminated with oil mist from the crank case ventilation system that flows back up the inlet duct after the engine is shut down. This can sometimes be fixed by removing and cleaning the sensor, in some cases the sensor may be faulty and need to be replaced. Check this thread for more info; http://www.nissanpatrol.com.au/forum...cking+cleaning
    Long term it's worth considering fitting a PCV (positive crank case ventilation) filter to capture the oil mist and stop the problem from reoccuring.
    Tony
  6. #16
    Banned
    To all new members & those member who have joined in the last 4 months I'd like to introduce myself
    Hi all my name is Paul (patch697) & I am the Super Moderator here on the forum. I have been away for a spell & there will be a lot of new members who haven't met me yet so I'd like to extend a worm welcome from myself to you all & if you have any question or need any help don't hesitate to ask.
    I hope you all enjoy the forum.
    Paul
  7. #17
    SUCH IS LIFE Maxhead's Avatar
    ACT
    G'Day and welcome to the forum mate
    ________________________
    ______ 2017 D-Max _______
