Page 3 of 3 FirstFirst 123
Results 21 to 27 of 27
Thread: New bar but can't fit. Need help.
  1. #21
    Quote Originally Posted by Covo71 View Post
    Would it really be a problem if I ground off the bottom of the body mount bracket level with the bottom of the rail?
    That would work for me, cant see it weakening the body mount any
  2. #22
    84 Post(s)
    Taking the tie downs off might be your only option in this case.
  3. #23
    Patrol Guru Covo71's Avatar
    Dec 2012
    Coffs Harbour
    Yep, cut them level and the bar went on without too much trouble after that. Thanks for the help.
  4. The Following User Says Thank You to Covo71 For This Useful Post:
    Clunk (9th April 2017)
  5. #24
    84 Post(s)
    After you clean up the rust and paint it, you might want to use fish oil or another anti rust product on the whole area. I used fish oil between the winch cradle, chassis and alloy bar to make sure no rust could start.
  6. #25
    On my other 4x4 with an ARB commercial bar I remember when it slid over the chassis rails
    other than the side bolts it also had one that went top to bottom.
    Good news its on ,,,,tick
    Covo71 (9th April 2017)
  8. #26
    Dec 2012
    Coffs Harbour
    I will douse it next day off. There is so much room to get in there before I put a winch in so will be easy as. Thanks for the help
  9. #27
    Dec 2012
    Coffs Harbour
    Yeah it had one bolt through the bottom but not through to the top. Cheers. Thanks for the info.
