Page 1 of 3 123 LastLast
Results 1 to 10 of 27
Thread: New bar but can't fit. Need help.
    Patrol Guru Covo71's Avatar
    Dec 2012
    Coffs Harbour
    I picked up the new bar today and tried to fit but the bar will not slide on to the chassis rails. After looking at it closer the body mount brackets have been very dodgy welding and obviously someone that doesn't know how to weld thought they would have a crack. As you can see on the photos they are bent in. I am worried given the crap welds if I start persuading this with a large hammer the welds might crack. Anyone with more knowledge than me got some advice. Chassis rail L.jpgChassis rail R.jpgChassis rail.jpgNew bullbar.jpg
    Definitely taken a battering haven't they!!!! Have you got a blow torch to apply some heat and maybe bend them back
    Dec 2012
    Coffs Harbour
    No, don't have a torch
    84 Post(s)
    If you only need to move them a few millimetres, try a hilift jack and some 10mm flat steel to gently pry them open.
  5. The Following User Says Thank You to mudnut For This Useful Post:
    Covo71 (8th April 2017)
    Legendary GQtdauto's Avatar
    Dec 2016
    Northeast Victoria
    41 Post(s)
    Welds are shit , rust is a big problem for you as well , not easy to weld vertical up with a stick but very easy vertical down with mig , no use putting a new bar on imo with it looking like that .
    Clean it up with a rotary wire brush or flap wheel if not both , if welds are holding okay just messy you can tap the bar in as long as you paint the weld area .
    If you find welds are dodgy it will pay to get them rewelded, if your fitting a bar your life sort of depends on it .
  7. The Following 3 Users Say Thank You to GQtdauto For This Useful Post:
    Clunk (8th April 2017), Covo71 (8th April 2017), mudnut (8th April 2017)
    Dec 2012
    Coffs Harbour
    Ah, the voice of reason. I will see if I can bend out and then check the welds and see if any visible cracks. If ok I will get some kill rust over the top to make sure it doesn't get more cancer in there. Cheers
    Scott
  9. The Following User Says Thank You to Covo71 For This Useful Post:
    GQtdauto (8th April 2017)
  10. #7
    22 Post(s)
    They're bent below the weld.. Just hit it straight
    96 GQ coil/Cab
    08 G6eT
  11. #8
    Dec 2016
    Northeast Victoria
    41 Post(s)
    As for having to force a bar into place I'm sure a few here have bought one that didn't quite fit right resulting in a bit of 5lb hammer love .
  12. #9
    do you have the inserts the right way around ,??All know is the drivers side has captive nuts
    and the passenger side has three holes that the insert lines up with,,,,just saying LOL
    If you were closer I'd be there in a heartbeat to help you out.....
    I'm with Ben just hit it straight....lol as it slides on from the inside of the chassis
    picking up those hole I mentioned then you use the shipping tie down as another
    fixing hole.
  13. #10
    fixing hole.
    Looks right to me
