Results 1 to 10 of 10
Thread: Clutch Slave Cylinder on Nissan Patrol GQ
    Mar 2017
    Hello,
    I have changed my slave cylinder some time back and it looked shorter than the one I took out? but the shop assured me that they only stock one type of slave cylinder for both Nissan and Ford GQ's.
    I have a feeling that the piston / rod that fits into the slave cylinder may be a bit short, because my clutch and gears don't slide in as easily as they used to before I changed the slave cylinder. I was under the Patrol a short time ago and I was able to take the rod / piston out of the slave cylinder with my fingers which suggest that it may be a bit short?
    Is it possible to buy the rod / piston bit and are there different lengths for the rod / piston, what length should it be?
    Thanks Roland
    Patrol Freak garett's Avatar
    Jan 2015
    north
    21 Post(s)
    did you keep the old one? i've done the slave in mine with no issues.
    did you bleed it from the bleed point on the pas side under the bonnet? ( not the slave and no not the master the other one that nissan put in to p you off)
    Mar 2017
    Hello Garett, I only bled it from the slave, I had no idea there was another one? - I think perhaps it's time for me to buy a manual. So there a bleed point on the passenger side under the bonnet? Thanks for this advice I will go and check now and get back to you. Thanks for your help. - Roland.
    Mar 2017
    Garett - Well who would have thought there were two bleed points! Is this the bleed point on the passenger side under the bonnet? and are we expected to let the Dot 3 brake/clutch fluid pour out on the paintwork? I went on line and purchased a new slave cylinder for the clutch, this one comes with the pin / piston insert so it should be the correct length.
    Which bled point to I bleed first the one one under the hood or the one at the slave cylinder? - Thanks for your advice and guidance. - Roland
    Jan 2015
    north
    21 Post(s)
    Quote Originally Posted by Rolsta View Post
    follow the metal line up towards the fuel filter, should be a bleed nipple, bleed it first then the slave. should be fairly quick if you have started bleeding it.
  6. #6
    334 Post(s)
    You should have been able to swap out the new shorter rod for the longer rod from your old slave? Do you still have that?
  7. #7
    Mar 2017
    Thanks Chaps for all the help - I'vw e ordered a New Slave and Pin - (The one I have installed does not appear to be original,) - when I bought the slave cyclinder it surprising did not come with a Pin so I used the same pin I had previously. - live and learn I guess - Thanks again.
  8. #8
    Feb 2012
    Camden, NSW
    I've had this problem with every vehicle I've owned that had a hydraulic clutch.
    Because of the design of the fork lever to multiply the push on the pressure plate, the wear on clutch plate, pressure plate, thrust bearing, fork end and fork pivot are multiplied by the same ratio at the slave end.
    Minis were the worst offenders, could add up to over 10mm and pop the piston out of the slave. Ended up getting an adjustable pin for them.
  9. #9
    Apr 2020
    Hello. Sorry for reviving a very old thread. But I have a similar question regarding the length of the slave rod. Can the rod be too long? I ask because the lever it sits on is pushed out beyond center and in my opinion, is causing my clutch to slip when the truck’s been heating up. Thanks
  10. #10
    Expert Dingbat MB TD42's Avatar
    Jan 2018
    Perth WA
    Quote Originally Posted by mmarchadesch View Post
    gday mate...you can carefully remove the master cylinder from your clutch booster...inside the clutch booster is an adjustable piston end...there is a locking nut in there so be carefull not to damage the piston... Wind it out a couple of turns and do the same with the nut and clip in the foot well on the other side of your firewall...this may get you a bit more reach outa your slave.
    Quad-Drive 4WD Club...Western Australia
    We're all here coz we ain't all there...
