Page 745 of 1057 FirstFirst ... 743744745746747 ... LastLast
Results 7,441 to 7,450 of 10565
  1. #7441
    I know what some of you think of 4wd supacenter, but I haven't had an issue with their product only their lack of customer service and delivery times.
    Drove down to the lilydale store on Monday and picked up a 2.5 x 2.5 awning, a side wall and a camp cooking stand/plate for $145.
    Just fitted the awning and with no problems.
  2. #7442
    Patrol Freak Mc4by's Avatar
    Oct 2016
    Mandurah W.A.
    7 Post(s)
    I have a set of their drawers, picked up on gumtree brand new. They went in easy and work great.
    I also got the awning and side panel. Took a while to get to W.A. but both look and work as expected.
    I have their solar panel in the garage which I haven't tried yet.
    It was a cheap way to get started and if I need to upgrade in the future so be it.
  3. The Following User Says Thank You to Mc4by For This Useful Post:
    jay see (6th April 2017)
  4. #7443
    @jaysee what are the plans for the awning one of those tie in rooms or just a tie in wall??
  6. #7444
    Legendary GQtdauto's Avatar
    Dec 2016
    Northeast Victoria
    41 Post(s)
    Some of their stuff is ok some not so much or needs a tweak or two , I have their drawers which for my GQ were a pita to fit but their new double thumper I recommend , also the awning mozzie mesh tent is good and awning seems just as good as more expensive brands .
    Have a bit more stuff from them from ARB and from TJM , disappointed with the latter two more than supercentre .
  7. The Following User Says Thank You to GQtdauto For This Useful Post:
  8. #7445
    @GQtdauto I use TJM as I got sick of looking at 4x4s with all the same options
    I need to be different, where in n/e Vic are you??
  9. #7446
    Dec 2016
    Northeast Victoria
    41 Post(s)
    Ok started the folding solar panel on the GQ today , first work out where the panels will sit bearing in mind I need four 10 litre jerry cans up top at front and a pole carrier and a chainsaw not to mention a bit of room for firewood so this was where they had to go .
    Folding panel had to be pulled apart , used a bit of scrap ply under rivets when drilling them out so I didn't damage panel , getting the silicone and mastic off proved a problem also removing the regulator was a half hour job .
    All off and cleaned up I tested how it would look and fit .
    Now to join the panels I have used silicone , rivets and button screws , had some aluminium angle left over from another job so used it each side and a folding leg from the solar panel to brace , strengthen and join panels together .
    Bloody connection boxes were higher than panel edge (see level) which meant a bit more working out but decided to put ali angle on the edge to give clearance .
    Once that was done I had a brain wave why not make it adjustable so I can tilt it east or west , then I worked out how to , need to go to town tomorrow for some bits and bobs and will also show photos of what I come up with .
    Not sure if all photos will send ok .
  10. #7447
    Dec 2016
    Northeast Victoria
    41 Post(s)
    First batch of photos can only do six photos at a time .
  11. #7448
    Dec 2016
    Northeast Victoria
    41 Post(s)
    Will post the other six photos when Puter behaves .
  12. #7449
    Dec 2016
    Northeast Victoria
    41 Post(s)
    Glenrowan
    Three dogs I'm based at good old Glenrowan .
  13. #7450
    Doesnt the reg need to be close to a battery???
    not far away at all..
