Page 1 of 8 123 ... LastLast
Results 1 to 10 of 75
Thread: Radio reception crap/ worse when motor is cold
    477 Post(s)
    So I've put up with this for long enough. The head unit is a chit Eonon unit, but I just need a radio and a screen for my reverse camera. And Blutooth. As of late I have noticed the radio reception getting worse. I just really noticed it today that it was really bad when the motor wasn't at optimum temps. But after driving the car for a while the radio reception was much better. Probably at around 90% of what it should be.
    I did notice also the reception got better when the revs dropped.
    Any ideas what this may be?
    .......... TPC's Avatar
    63 Post(s)
    What is the condition of your battery or batteries?
    A dodgy main or aux battery can create problems for radio reception which will improve as the battery charges.
    Does it get worse if you put the headlights on?
    Expert Mike02Ti's Avatar
    Jun 2016
    Rockingham WA
    4 Post(s)
    Earth gone bad maybe? Either on the head unit itself or the antenna.
    Did you use an adapter for the antenna plug into the back of the unit?
    2002 GUIII Ti 4.8
    Details here
    477 Post(s)
    Haven't tred with the headlights mate. I will give it a crack tomorrow. The batteries aren't that old and get a good top up charge every few months.
    Quote Originally Posted by Mike02Ti View Post
    I did have an adaptor but now I'm using a GME whip antenna so no adaptor need now.
    Feb 2012
    Camden, NSW
    Could be static from the allternator. Is there a high frequency whining sound that changes with engine revs? Also worse when the alternator output is higher ie. charging
    Static can either come through the power, earth or airborne to the antenna.
    If you have a portable radio see if it is affected, that will test if it is antenna issue or not.
    I remember years ago you used to get suppressor capacitors that fitted to the alternator output terminal.
  6. #6
    477 Post(s)
    I did notice it changed with the revs. Yeah i remember those suppressors too. But they were fitted to the ignition coil from memory...
  7. #7
    Legendary dom14's Avatar
    38 Post(s)
    Even though it looks like cold engine, rev related, probably it has more to do with weak connection the antenna, power or the antenna/radio itself.
    Radio antenna line ideally should have a noise filtering on itself.
    Few more mods on the way
    https://www.panthera.org/
    Cheetah Outreach
  8. #8
    177 Post(s)
    Believe it or not Mark. Mine is identical! Exact same symptoms.
    It done it with factory aerial .
    Then i completely cut it out and disconnected it and installed a Gme whip antenna like yours and issue is still present.
    However mine only does it when motor is running. Motor off brings perfect radio reception.
    But i never listen to radio anyway so i just ignored it.
    Edit: mine is a pioneer head unit.
  9. The Following User Says Thank You to Hodge For This Useful Post:
    mudski (4th April 2017)
  10. #9
    Just because the batteries arent old doesnt mean they are not the problem.
    Id be fitting an inline noise suppressor.
    OOI I still use the OE antenna and have a "chit" eonon head unit and have no problems
    whats so ever
    Had a think I reckon you may have a "burnt" wire somewhere
  11. #10
    Jun 2016
    Rockingham WA
    4 Post(s)
    It does sound like you have a ground loop of some sort. Have you added or changed the routing of any wiring ?
    As TD says abut his Eonon , mines fine too. Even with stock antenna
    2002 GUIII Ti 4.8
    Details here
