Results 21 to 30 of 45
Thread: Brakes Problem
  1. #21
    Cairns, Far North Qld
    It is a Patrol thing. Because the booster on them is so big and effective, it gives the symptoms of a bypassing master cylinder.
  2. #22
    Patrol Freak BillsGU's Avatar
    Jul 2010
    Thurgoona
    7 Post(s)
    I had the same symtoms as you have and had it to many mechanics (and brake specialists) to fix with no improvement. I heard about the LPV problem and bled it myself. A whole lot of brown muck came out of it. The brakes did improve a bit so I took the valve off the Patrol and when I had a close look at it I noticed it was partially stuck. I went to a wrecker and picked up one off a recent Patrol, fitted it and the brakes are now good as new.
  3. #23
    May 2016
    lower west victoria
    30 Post(s)
    What year is your GU Bill??
  4. #24
    Jul 2014
    6 Post(s)
    Small hijack, but is there a '2nd stage' to the pedal? Ie, when I depress the pedal far enough under extreme heavy braking, does the pedal get to a point and then hit another rod or something to increase braking pressure? Or is it all in my head.
  5. The Following User Says Thank You to Throbbinhood For This Useful Post:
    dom14 (30th March 2017)
  6. #25
    Legendary dom14's Avatar
    38 Post(s)
    Quote Originally Posted by Throbbinhood View Post
    There's only one rod on the master pump. May be you're feeling the LPV kicking in??!!
    Few more mods on the way
    https://www.panthera.org/
    Cheetah Outreach
  7. #26
    Jul 2014
    6 Post(s)
    Quite possibly. All I know is I can feel some sort of feedback in the pedal and then the thing just stops haha!
    Hey mudski I think it was you, you were mentioning the pedal slowly going down, how do you find it on long steep downhills, say out in the high country? Ever run out of vacuum and subsequently out of brakes?
  8. The Following User Says Thank You to Throbbinhood For This Useful Post:
  9. #27
    Feb 2012
    Camden, NSW
    LPV will give the feeling of 2 stages under heavy braking.
    Initial braking causes weight transfer to front, LPV senses this and reduces pressure and fluid to rear brakes.
    As you slow down more weight transfers back to the rear and the LPV will then start increasing the pressure and fluid to rear brakes.
  10. The Following User Says Thank You to Turtle_au For This Useful Post:
  11. #28
    Jul 2010
    Thurgoona
    7 Post(s)
    It is a 2000 GUII.
  12. #29
    Expert Col.T's Avatar
    Nov 2010
    Seaview Dwns.S.A.
    G'day 10G man.
    Seems to me, a brake system is fairly simple.
    Bang your foot down,,,master cylinder shoves pressure down the tube,,,,,,
    slave cylinder slams pressure into the pads. All 4 wheels.
    You've got a few points at which there could be a weakness/leak/failure.
    4 wheel acting points. Got leakage???
    The balancing point at the ars*nd of the system?? I've never seen leakage there but?.
    I think (although I'm usually wrong), that if there's visibly no leak at any of those points, the only problem can only be the master cylinder with some bypass system involved.
    Can't remember how those bypass/safetypass/whatthehellpass systems work but if , as said, there's no leak elsewhere I'd be looking for a new master cylinder.
    Good luck,
    Col.
  13. #30
    Expert billyj's Avatar
    gordon
    3 Post(s)
    keep bleeding, when i did new master, lines and reco calipers on my gq it must have taken about 3 litres of fluid before all the damn bubbles were out and i had a good solid pedal
    gone to the dark side 2017 vdj 79 dc
  14. The Following User Says Thank You to billyj For This Useful Post:
    dom14 (4th April 2017)
