Page 37 of 77 FirstFirst ... 3536373839 ... LastLast
Results 361 to 370 of 762
Thread: Jay see 1997 GU build up
  1. #361
    Depends on what it is I suppose. I try to have a common earth point in different sections of the car. Only for trouble shooting if need be really.
    Nothing over the top.
    A merit plug for the fridge and then some 12v charging points and some led light bars.
  2. #362
    Dvb-t arrived yesterday as I was leaving for work.
    Couldn't wait so I gave it a quick wire in to see how it goes when I got home.
    Only manage to get ch31, but I'm hoping that's only because of the antennas that the unit came with.
  3. #363
    You should first scan channels which Im sure you did.
    different locations will have different reception.
    I found the Aust made Laser antenna the best available
    I receive all channels available from free for view
  4. #364
    @jaysee here you go the reason behind the 780mm and not the larger
    one is so you will fit under most car ports, Im sick of breaking tips off
    antenna. lol
    http://www.ebay.com.au/itm/780-Laser...cAAOSw7NNT8TrD.
  5. The Following User Says Thank You to threedogs For This Useful Post:
    jay see (6th February 2017)
  6. #365
    Got a few things done the last few days.
    Also ran a heap of wiring under the dash for a bank of switches.
    What kind of switch should I be running on the bullbar for the winch?
  7. The Following 3 Users Say Thank You to jay see For This Useful Post:
    gubigfish (19th February 2017), MB (19th February 2017), Touses (19th February 2017)
  8. #366
    482 Post(s)
    Winch switch sorted. Just need to do a simple switch on the bar and some light for the isolator.
    I like that location Jaysee, well done mate, gonna have to copy that if ok mate! Can be easily reached in and out of cab if needed, GOLD :-) !
  9. The Following User Says Thank You to MB For This Useful Post:
    jay see (19th February 2017)
  10. #367
    Aug 2014
    Perth
    10 Post(s)
    Where did you get this from? I take it it reads the voltage for whatever battery its connected to?
  11. The Following User Says Thank You to gubigfish For This Useful Post:
  12. #368
    Didn't think of it that way.
    I put them there so they're in easy reach while in the drivers seat.
    Copy away mate, we're here to share ideas.
    Quote Originally Posted by gubigfish View Post
    EBay.
    http://www.ebay.com.au/itm/201749493170
    Yes, correct same as the one behind the centre console.
    Thinking I might move that one to the rear cargo area. Kids don't care what volts there is.
    Also did an oil and filter change on mine, the wife and the father in law cars.
    Rotated my tyres and one side needed a wheel bearing nipped up, but couldn't find my cut 8mm Allen key.
  13. The Following User Says Thank You to jay see For This Useful Post:
  14. #369
    477 Post(s)
    And its 4.2A. I wonder if thats true. Most I've seen are only 1 or 2 amp. Barely enough for most devices these days. Might haveta get one I reckon.
  15. The Following User Says Thank You to mudski For This Useful Post:
  16. #370
    What's why I got them.
    Will put a mulitmeter to it and report back.
  17. The Following User Says Thank You to jay see For This Useful Post:
    mudski (19th February 2017)
