Results 1 to 5 of 5
Thread: Need some help with polish.
    Patrol Guru Covo71's Avatar
    Dec 2012
    Coffs Harbour
    I have done some work on the old girl and everything I look up on what to use after painting is to buff clear coat. The problem is it is on the back corner of the roof and down the side of the channel. If I use a buffer (which I don't have) I am worried I will burn through. I am far from being a professional. What should I use to polish / buff? Is it just a cut polish?
    Dec 2012
    Coffs Harbour
    Jan 2018
    I may be to late to reply,
    However I use Menzerna Polish : http://menzernapolishes.com.au/products/polishing/
    I’d recommend PF2400 to polish,
    Then SF3500 to refine the paint.
    As for burning through the paint, work small patches of the panel at a slow speed
    Moving over the same area slowly about 6 times, wipe off after this, inspect the paint and if your happy move onto another area of the panel.
    I suggest doing it in a cool shaded area as the panel can heat quite a bit and you don’t want to burn your new paint.
    Allan
  4. The Following User Says Thank You to sarefeet For This Useful Post:
    MudRunnerTD (1st August 2018)
    Jan 2018
    It can be done by hand, however it will take longer for the polish to break down
  6. The Following User Says Thank You to sarefeet For This Useful Post:
    Aug 2018
    But it would take much time to polish with hands, not a better idea, but good and interesting work with hands...
    Keep calm and carry on
