Page 1 of 3 123 LastLast
Results 1 to 10 of 27
Thread: 285 vs 265
    Dec 2015
    285 vs 265
    Looking for a few opinions.
    Currently running 295/70/17 Nitto Trail Grapplers. Looking at changing tyres to something smaller due to doing some fairly serious k's soon (Adelaide to Gibb River Road and back for a start)
    Pretty keen on the K02's, just wondering what people think about whether the 285's are worth the extra cash over the 265's...local supplier has quoted $400 vs $339.
    Will be used for everything from rocks, sand, mud, hills, etc.
    On a '09 GU
    Cheers fellas
    Depends on if you need that extra inch of diff clearance
    I'd go 265s if majority was sealed or dirt roads where diff clearance isnt an issue as Clunky referred to.
    Dec 2015
    Cheers guy, would the fuel economy difference be anything worth paying attention to or would it be pretty negligible?
    You'd already be $240 in front with the 265s by the prices you quoted, and even though negligible difference in fuel economy between the two you'd only get better economy from 265s v 285s. I'd say go 265s if you're not scratching for clearance. Know how to vary tyre pressures for varying grip in different terrains.
  6. #6
    477 Post(s)
    Personally I would go the 285's. In my opinion the slight higher clearance will help especially if your in ruts etc etc. Last thing you want it to be dragging the diff centre on the centre of a rutted track. Thats a show stopper every time. I get it on the rear diff even with 315's as my rear diff is the larger H260 diff. Kinda wish it wasn't for this reason.
    On the highway your fuel eco should be better with the larger tyre, more speed for less revs, but it will be opposite when in low range or slow stuff. But the difference either way would equate to sweet fa.
    Your usage is rocks, sand, mud, hills etc. So to me the 285 is a no brainer. That little extra clearance over the 265 will help. Each to their own though.
  7. #7
    Not sure that statement about a bigger tyre give better fuel to be true.
    When I put my 305s on my fuel figures go up.
    Even here the best fuel figures are ppl running 265s.
    A large tyre and small motor is more effort required to turn them.
    Id go the 265 every 25mm you go up is only 12mm gain in clearance
    so very minimal imo
  8. #8
    Ballarat, Vic
    178 Post(s)
    For the Adelaide/GRR trip, whichever way you go I can’t see any advantage for 285’s over the 265’s. The choice is probably best determined by what other driving plans you have.
  9. #9
    Legendary happygu's Avatar
    so very minimal imo
    TD, you have to remember that the larger tyre size will give you more distance for every rotation of the tyre, so in fact fuel consumption may not end up more at all.
    In the OP, the tyre sizes talked about were 265 and 285
    In a 265/70R17 tyre you may have a rolling diameter of around 804mm ( depending on brand, of course )
    For the same brand tyre in a 285/70R17, you will have a rolling diameter of 832mm ....
    What this means, is for every time your engine is running, for the same RPM you were doing on the 265 - on the 285 you will go 28mm further ..... that is why bigger tyres suck more energy out of the engine because the extra power required to turn the tyre a complete rotation, it means the car has to travel further.
    This means you are going 3.5% further ( than your odometer is reading and what you were on the smaller tyres ), and if your fuel consumption has gone up less than that, you are actually in front ....
    My fuel consumption probably went up slightly, at around 4 - 5%, so for the minimal extra fuel use, I get around 20mm more diff clearance with the bigger tyres.
    My opinion is to go for the larger tyres, but for years and years, I stuck with original size tyres and went all over place.
  10. #10
    Ive never heard of anyone getting better fuel figures by fitting latger tyres,
    as soon as I fit my 285 I get 15/100 when I had the OE 265s My fuel figures were 12/100k
    I will go with a HWY pattern will be better than a MUD pattern for fuel and braking
    Larger tyres play havoc with your braking ability as well
    The patrol is designed to run best with gearbox and diff ratios on 265s
    so by running 35s I travel further and get great fuel economy NAH wont work
