Results 1 to 7 of 7
Thread: Zd30 crd (limp mode) no power
    Apr 2016
    Sydney
    Hi guys
    Now I'm having trouble with my ute
    Starts fine runs fine except I seem to be
    Going to limp mode (loss of power) and engine light on
    It's boosting fine 17psi.
    Don't seem to be any leaks, checked oil filter seems
    Good. Can't put my finger on it any help or
    Ideas would be greatly appreciated.
    I have egr blocked completely (both sides)
    Egr delete , full nads
    Also can't put it on the scanner seems to
    Have no power to where it plugs into, any ideas.
    SUCH IS LIFE Maxhead's Avatar
    ACT
    I would pull all that crap you have on there( otherwise called nads) and try again
    ................on the road
    ________________________
    ______ 2017 D-Max _______
    Legendary happygu's Avatar
    Leave the EGR blocked initially, and put all the hoses back to standard, and see what happens....
    If it still continues, try putting the EGR back to standard too, as there are some that just like the 10mm Hole in the Blanking Plate to be happy.
    I would of backed the boost off a tad to say 15-16psi
    dis connecting the battery as you do it,,,, for 1/2hr or so
    see how that goes.
    Feb 2012
    Camden, NSW
    I would suspect ECU if it won't scan.
  6. #6
    477 Post(s)
    Quote Originally Posted by Rsayers View Post
    Hi guys
    Now I'm having trouble with my ute......
    What scanner are you using? The scanner might not be compatible, or even not working.
  7. #7
    Apr 2016
    Sydney
    Scanner works and has worked on this ute before, I've tested it to see if power
    Is getting to the plug and it seems only a few of the pins are actually getting power
    I've put 4 different scanners on it with the same result
