Results 21 to 30 of 33
Thread: Assistance required urgently
    Patrol Guru
    Jul 2014
    6 Post(s)
    if anyone can help.
    Where are you located mate? If your not too far from me I may be able to pop in after work.
  2. #22
    pm sent yeah its got me beat ATM
  3. #23
    Patrol Guru
    Jul 2014
    6 Post(s)
    Sorry guys, 3D is a couple of hours away from me. Hopefully someone a bit more local to him can help.
  4. The Following User Says Thank You to Throbbinhood For This Useful Post:
    threedogs (8th February 2017)
  5. #24
    Im in contact with Mark via TXT hopefully he will have a solution
  6. #25
    .......... TPC's Avatar
    63 Post(s)
    any one know the trick to move the belt tensioner, Ive a 600mm brako bar with a 19mm socket and I cant move it at all
    At least the alternator is in, sweating like a pig atm, warming right up now.
    I used a ratchet strap on the bar last time, made it easy.
  7. The Following User Says Thank You to TPC For This Useful Post:
  8. #26
    it moved ok removing the belt same as last time
    GGGrrrrr given up friggen Patrols
    this tensioner aint moving anytime soon.
    now its hot I cant walk it too much grrrr
  9. #27
    84 Post(s)
    Are you n the RACV roadside assist? Tell them the belt broke and you need to put on the spare.
  10. The Following User Says Thank You to mudnut For This Useful Post:
  11. #28
    all done the tensioner was hitting the aircon housing.
    Needed a small "TAP" to move it so all is good.
    Happy man now , just need to put the rest togetherand go for a drive. 37 and a cool change tomorrow Aggghhhh
  12. The Following 2 Users Say Thank You to threedogs For This Useful Post:
    dom14 (9th February 2017), mudnut (8th February 2017)
  13. #29
    If I was home I would have popped over John, but I've got my hands a little full atm.
    Good to see that you got it it on. 👏
  14. The Following User Says Thank You to jay see For This Useful Post:
    threedogs (9th February 2017)
  15. #30
