Results 1 to 10 of 10
Thread: Water pump S#&t the tin
    Advanced Finezy's Avatar
    Geelong - VIC
    Zd30 Water pump S#&t the tin
    Hey ladies and gents
    As the Title suggests my water pump has crapped itself, well the seals have and water is leaking from the "weep hole".
    Are there any aftermarket alternatives I should consider to save a dollar or are they all rubbish?
    Any help would be greatly appreciated.
    Sorry, should specify its for a zd30, my bad.
    Last edited by Finezy; 29th January 2017 at 06:12 PM. Reason: Missed vital information
    Expert graeme1969's Avatar
    Jun 2013
    Wesley Vale, Tas
    Bloody Aussie on this forum had a really good one fitted. If mine died that would be the way I would go. Do a search on here and you should be able to find the details.
    83 Post(s)
    graeme1969 (29th January 2017)
    Geelong - VIC
    Hey cheers guys, i have edited my post so people dont have to try and guess what motor i have haha
    Even give Patrolapart a ring tomorrow for a second hand one too if you're on a budget mate
  7. The Following User Says Thank You to AB For This Useful Post:
    Finezy (29th January 2017)
    Geelong - VIC
    Yeah had a look on there website, they have genuine for $300 which I am happy to pay if its new but if its a re-build I'll look at other options.
    I just had a look around and noticed Gates does water pumps for the zd30 and they can be had anywhere from $315 to $375 brand new.
    If anyone has had any experience with the gates water pumps id love to hear some feed back.
    2001 GU II ST, 3.0di, Auto, All NADS done, Nissan Snorkel, 50mm Lift, 35's....
  9. The Following User Says Thank You to Finezy For This Useful Post:
    AB (29th January 2017)
  10. #7
    I'd be interested in the remove and replace proccess.
    I was going to replace mine but I feel the viscous hub is fine.
    I brought mine from autopartsonline from memory
    The one BA brought had a bronze fan blade instead of a pressed
    tin job. still not the best going around but is best atm'
    John Bennet water pumps had impellors and he die ground
    most surfaces to eliminate cavitation as much as possible,
    but they are no longer available sadly
  11. #8
    Geelong - VIC
    The water pump, pulley and viscous hub are all one unit which I had no problems removing mine using 6 or 7 easy steps which i found on the forum. It was actually quiet easy.
    I found out that the pumps which Patrolapart offer for $299 are actually genuine and brand new so I ended up ordering one of them this afternoon. Should have it b4 the weekend.
  12. #9
    How many K's have you on your motor??
  13. #10
    Geelong - VIC
    Probably around the 60k mark, the previous owner had a brand new crate motor fitted and all the nads and stuff done straight away, he had done 40k prior to me purchasing the car and iv done atlest 20k.
    Since comparing the new genuine pump to the old one im pretty sure the pump that crapped itself was an aftermarket one.
  14. The Following User Says Thank You to Finezy For This Useful Post:
    threedogs (3rd February 2017)
