Results 11 to 20 of 31
Thread: Front LOKKA questions
    You'll love it and completely change your driving but I did get a little sick of the heavy steering when all day off-roading to be honest especially in the high country but I found a work around by using 4h a lot more and on the fly back to 2h
  2. The Following User Says Thank You to AB For This Useful Post:
    RB30Turbo (18th January 2017)
  3. #12
    Oh you do that too...... got a Spartan in mine, works well. Don't get any clicking either. ..... well not that I've noticed
  4. The Following User Says Thank You to Clunk For This Useful Post:
  5. #13
    Expert Skitzyrex's Avatar
    Jul 2013
    I had one installed on Saturday and had replacement 4.11 diff centers put in at the same time. I got to the mechanic at 7 and was gone by 1 and that was putting the back center in also. Didn't look like a complicated task and if I hadn't just had a hernia op I would probably give it a go. The rattle gun certainly made a difference.
    I'm yet to test it but have been told to just take it easy until you get use to it.
    2007 GU ST-S 4.8 Patrol.
    40mm heavy duty springs, Dual batteries,
    140 ltr fuel tank,Custom 60ltr water tank, draws, cargo barrier, bull bar, IPF spotties, UHF.
  6. The Following User Says Thank You to Skitzyrex For This Useful Post:
  7. #14
    Beginner RB30Turbo's Avatar
    Jan 2017
    Thank's for the reply's fellas.
    Sounds like there's fairly varied opinions but the general consensus is that they're not a bad bang for ya buck...
    I'll give one a go and see what happens
  8. #15
    Patrol Guru Rock Trol's Avatar
    Mar 2013
    NE Melbourne
    Quote Originally Posted by RB30Turbo View Post
    Good call!
    They are probably the best bang for your buck that you can get. They certainly work well and for the $380 or so for the LOKKA it leaves money for other mods. Easy to steer with them in 4WD, just back off the throttle, turn wheel and then apply power again. You just need a short time to learn how it behaves and then you wont notice it the front most of the time.
  9. The Following User Says Thank You to Rock Trol For This Useful Post:
    growler2058 (18th January 2017)
  10. #16
    Feb 2011
    Shed
    45 Post(s)
    Quote Originally Posted by Rock Trol View Post
    Good call!
    Yep that's what i found. Just a bit of throttle control and away you go. I was able to steer in sand and dirt with 1 finger in the Q
  11. #17
    I wouldnt put one in the front, like my steering too much.
    with 330rwkw Id opt for a selectable locker.
    I know heaps of guys with those rear kw figures
    and not one has chosen to go an auto locker in the front or rear for that matter
    In fact most pulled out their ARB lockers in favour of a TJM Pro Locker.
  12. #18
    176 Post(s)
    Just curious, who is "most" ? Not being biased or anything towards ARB or against TJM.
    Feb 2011
    Shed
    45 Post(s)
    HAd F&R ARB in a holden v6 gutlux non power steer and it was HEAVY. Didnt like it for my application
  14. #20
    Don't know anyone in the comp scene with TJM lockers. They all run ARB or Eaton elockers.
