Results 1 to 10 of 17
Thread: Provent Catch Can installation help
    Apr 2016
    Daisy Hill, Qld
    Hi
    Im going to be installing a Provent 200 in my 2011 CRD and would like to know where people have installed the catch can (photos please). Also I have been told that you need to reduce the size of the hose coming from and too the catch can back to the fittings on the engine and air intake, is this true?
    Also have i got the right hose where the catch can needs to be installed? (see pic)
    Thanks in advance
    177 Post(s)
    Hi Clffy. I made up a little L bracket setup and used existing captive threads on the fire wall to hold up my catch can on the CRD. Pictures will tell you more. This was my backyard job/idea and it worked. Others I have seen have a more professional approach. I'm not much of a fabricator.
    As for reducers. I don't remember its been a while since i sold my 3L. The catch can out side I had to reduce...
    Also a word of advice. Across the web and other forums, some suggest a xc-xb falcon heater hose... One side of that hose has flared ends and it fits perfectly... However, the heater hose doesn't like oil. I used one (you can see it pictured), and within a year it deteriorated. Stay away.
    Sorry i cant remember exact hose sizes/reducers.
  3. The Following User Says Thank You to Hodge For This Useful Post:
    Cliffy (17th January 2017)
    They say you can use Ford XA heater hose as it has flared ends.
    Ive noticed on ebay you can buy the correct size hose barb,,, to
    eliminate heaps of hose clamps etc, I'll try and find the link for you
    have a search and you'll end up finding what hose barb you need,,
    there are plenty of sizes, type in "Provent catch can adaptors"
    http://www.ebay.com.au/itm/Provent-2...YAAOSwvg9XXfZ0
  5. The Following User Says Thank You to threedogs For This Useful Post:
    177 Post(s)
    Did you read what I wrote before John. Those heater hoses are no good, even though they are an absolute perfect fit ... They do not like and are not designed for handling oil or oil fumes.
    Sent from S5
  7. The Following User Says Thank You to Hodge For This Useful Post:
    Bacho86 (17th January 2017)
  8. #5
    Unafordable
    4 Post(s)
    Mine is Di so I'm not sure what size is the rocker cover fitting on CrD but you can buy the whole shebang complete with hoses to suit your Patrol from Western filters, no need for reducers as hoses are molded correctly Provent-200-oil-catch-filter-kit-12mm-16mm-for-Nissan Patrol/
    and
    here are the installation instructions/notes ==>
    provent-kit_prov10_nissan-patrol_2007-2015.pdf
    Regards
  9. The Following 5 Users Say Thank You to Rumcajs For This Useful Post:
    Cliffy (17th January 2017), Hodge (17th January 2017), MudRunnerTD (21st May 2020), stoj34 (10th December 2018), Vuck Roger (18th January 2017)
  10. #6
    177 Post(s)
    Quote Originally Posted by Rumcajs View Post
    Mine is Di so I'm not sure what size is the Rocker cover fitting on CrD but you can buy the whole shebang complete with hoses to suit your Patrol from Western filters no need for reducers as hoses are molded correctly Provent-200-oil-catch-filter-kit-12mm-16mm-for-Nissan Patrol/ and here are the installation instructions ==>
    Regards
    I actually bought my Provent from them. Without any fitting kit or hoses. Then after the heater hose fiasco, I messaged them and they sent me a kit with reducers etc... Thats the reducers you can see in the first photo....
    This new kit you linked is different and looks much better.
    Apr 2016
    Daisy Hill, Qld
    Thank you all for some great idea's and advice, much appreciated
    Definitely going to look into those catch adapters on ebay
  12. #8
    Jan 2017
    Great post!
  13. #9
    Here is my install.
    No reducers, used self gluing heat shrink..
    http://www.nissanpatrol.com.au/forum...ad.php?t=36453
    Sent from my SM-G800Y using Tapatalk
  14. The Following 2 Users Say Thank You to BigRAWesty For This Useful Post:
    Cliffy (18th January 2017), Col.T (24th January 2017)
  15. #10
    Mar 2016
    Heres some pics of where i installed mine. was a tight fit due to the abs module and vacume pipes.
    I got my a bunch of "make your own bracket" sheets from bunnings. They come in a bunch of sizes. I worked out i needed 3 sheets to attach and offset on the black bracket holding the vacume pipes, which actually brought it closer to black bracket to clear the abs moudule piping. See photos for some ideas..
    Had to put a little twist to move vacume pipe to one side, but all fitted in nicely.
    Take some time dry fitting to make sure it clears everything and you will have no dramas...
    Also fitted a bit of clear to drain with tap on end and routed using some cushioned clamps.
  16. The Following 2 Users Say Thank You to Joshforrest For This Useful Post:
