Here's another few points to ponder when "joining snatch straps"...
Should two snatchies be joined at all?... some manufacturers say you shouldn't others don't specify one way or the other.
What are the implications if they are different ratings and/or different lengths... most manuf (if not all) say the rating of the strap in use should be 2 to no more than 3 times the gross weight of the lightest vehicle in the recovery...
If you have joined, say, a 6,000 KG strap to a 9,000 KG strap what effect will the larger strap have?
Would you or have you in the past joined two straps (I know I have but don't anymore) or reached for the winch extension strap and the snatch strap
