Page 1 of 5 123 ... LastLast
Results 1 to 10 of 43
Thread: Intercooler fan yes or no ?
    Dec 2016
    Yarrabah
    While looking for anew inter cooler I noticed a lot being offered with an electric fan attached.
    Is it worth while having a fan on your IC ,just putting it out there ??
    Craig
    G'day Craig, I'd say it depends on the intended truck usage mate. If it were for highway use then I'd imagine the scoop would do all the work needed. I'm thinking for low down slow crawling applications a fan would near be essential to stop heat soak on top mount IC's.
  3. The Following User Says Thank You to MB For This Useful Post:
    Hodge (8th January 2017)
    there has been lots written on this topic have a search and see what you can find,
    Depends what you use your Patrol for,,what motor /IC do you have
    176 Post(s)
    My cross country IC arrived with a fan fitted. I wired up a in-dash switch so i can manually turn it off or on. As MB said, general driving around town or on freeway it makes sweet f*** all difference with fan on or off. If the cross country intercooler is as good as they say it is, I don't know why it comes fitted with a fan.... But anyway I left my fan on and wired it up.
    I haven't yet tested it under crawling conditions though.
    However... I have a enormous ARE scoop which scoops up a lot of air movement while vehicle is at speed. So...
    My guess is, (and this is only my guess) cars with standard size intercoolers and/or scoops will benefit much more with a fan, than the larger intercoolers and/or scoops. The fan will promote more air flow.
    My 2c.
    I agree with what MB says here. In fact at highway speeds or even general road speeds, a fan is more of a hindrance than a help.
    But offroad at speeds below 40kph then fan does help a fair bit then.
    I have a fan on my cross country cooler wired to ignition so it is always running. I would forget to switch it on at low speeds if I had it on a switch, and I think it helps with heat soak when stopped at lights etc, it always has cooler outside air flowing through it so doesn't soak up as much heat from the engine.
  7. The Following User Says Thank You to Winnie For This Useful Post:
    mudski (9th January 2017)
    Aug 2011
    River Heads Q
    4 Post(s)
    In theory a fan should help at all speeds if set up properly as standard set up does allow air to flow through all the intercooler as can be seen from attached photo of mine. Back half is dirty from air and dust hitting top of intercooler but front half is as clean as a whistle. Standard scoop & intercooler.
  9. The Following User Says Thank You to Wizard52 For This Useful Post:
  10. #7
    From the info I received when I brought my ARE scoop was the STD scoop
    doesnt really do much till you hit 80KPH, with the ARE scoop fitted that drops down to 60KPH
    Heat retention would be the enemy, Not sure which is the best way to wire one up.
  11. #8
    Dec 2016
    Yarrabah
    Hi guys
    Thanks for your feedback , I have seen them wired up to a thremocouple fitted to the outlet
    of the IC so it comes on when the air temp reaches a certain point .
  12. #9
    Expert clubbyr8's Avatar
    Penrith, NSW
    3 Post(s)
    I mounted a 10" or was it 9" fan under the standard intercooler so it sucks air through the IC. It's wired via a Jaycar 50 C normally open thermostat switch that's connected to the IC outlet. I've also got a manual override switch in the dash. It sucks a lot of air through the IC and only comes on when the temperature rises above 50 C. Doesn't come on much at highway speeds but works well in traffic....
    GROOVY GUVII
  13. #10
    Patrol Freak jff45's Avatar
    Morayfield, QLD
    13 Post(s)
    I use a 12" Davies Craig fan under a 450x300x76mm core size which is also controlled by a Jaycar 50C temp switch and in dash override (which I've never had to use).
    IMO, they are needed. The IC is a massive heat soak when the engine is shut down for only a short period, e.g. stopped for shopping, and the the scoop acts as a chimney to funnel all the engine heat up through the IC.
    John
  14. The Following User Says Thank You to jff45 For This Useful Post:
    relyimah (10th January 2017)
