Page 34 of 35 FirstFirst ... 32333435 LastLast
Results 331 to 340 of 343
Thread: Installing WRX front mount intercooler with 3" pipe to GQ
  1. #331
    Quote Originally Posted by Bloodyaussie View Post
    ?????????????!!!!!!!!!!!!!!!!!!!!!!!!!!??????????? ??????????????? what you on about?????????????????????????????!!!!!!!!!!!!!!!! !!!!!!!!!!!!!????????????????????????????
    I personally dont like powder coating for bar work as once it is chipped away it is hard to tidy up.
    I prefer paint then it just needs a dust up every now and then.
    I only got the Bar primed as I was not sure how long until you would paint it so did not want it to rust.
    The scrub bars I did not get primed as I knew I would be painting straight away.
    I could bring the bar to the ARB night?? I am going to need your bar pretty soon.
    Yeah no probs mate. ill have to strip my bar at home but I can take the rodeo at work and bring the bar in the tray as it will be a pita trying to get everything back on in the car park at 9pm at arb.
    Do you want to do that?
    I just didn't know if you were just going to leave my bar as is and throw it on your car or if you were going to spruce it up and respray it. It's actually in pretty good nick, no dents or deep scratches, etc...
  2. #332
    Advanced MrSka's Avatar
    Dec 2013
    RockVegas, Central QLD
    So was there a reason you picked a wrx cooler, or was it just what you had? I'm looking at buying one of these from justjap:
    Mainly because the piping for my RD28 GQ will be so much easier then having to pipe it all the way back round. I plan to either mod my stock plenum to be like this:
    Or use a GU RD28 plenum, and rotate the intake 90 degrees.
    97 GQ RD28t Wagon, needs a new crank
  3. #333
    Quote Originally Posted by MrSka View Post
    Purely because a friend was giving it away mate with a lot of piping that could work that's all. I won't lie though, it was a bit painful trying to get it all to work though being a full custom fit.
  4. The Following User Says Thank You to AB For This Useful Post:
    MrSka (25th August 2014)
  5. #334
    Sep 2014
    Haven't ever tuned my turbo. Probably why it seems like there isn't one there
  6. #335
    Sep 2014
    Do you know if anyone has put an atmospheric blow off valve on a gq before??? just curious
  7. #336
    334 Post(s)
    Quote Originally Posted by TurboYoda97 View Post
    No point on a Deisel mate.
  8. #337
    22 Post(s)
    Only need one if you run big boost and suffer from compessor surge. The kit is about $700 from memory
    96 GQ coil/Cab
    08 G6eT
  9. #338
    Patrol Guru 89gqpatrol4x4's Avatar
    Brassall
    Thread dig here sorry mate! To get your cooler back you cut that vertical bonnet catch steel bar off and took off your aircon thermo?
    Any negative affects on aircon? And any affects of removing that support?
    How's the cooler lasting over the rigures of 4 wding?
    Nice work too mate keeps it subtle!
  10. #339
    Quote Originally Posted by 89gqpatrol4x4 View Post
    Hey mate ABs away for a few days but have a front mount on my GQ. Yeah removed vertical support just a couple of bolts top & bottom. Didnt notice any difference really maybe bonnet needs a firmer slam to shut but that might just be my catch. Took off the thermos for the aircon too, still works beutiful the only loss will be aircon might not get icy cool if just sitting there idling cos it's not getting airflow but hasn't been an issue at all with mine really. .
  11. #340
    Brassall
    Cheers Rossco. Did you run your pipe work the same and did you rubber mount the intercooler ?
