Results 1 to 6 of 6
Thread: Sump protectors
    WA Wheatbelt
    23 Post(s)
    Sump protectors
    Seeing the undercarriage of Dogman's old patrol reminded me about sump protectors.
    Does anybody have one? What are the pro's and con's, if any?
    Ross
    Banned
    Not yet but I'll be watching this so I can get some ideas..... Thanks in advance Guys.
    Paul
    Patrol God Finly Owner's Avatar
    Jul 2010
    Waterford West Qld
    I have to fit Finly. Apparently factory option. All the Endeavour rally cars have them. the best I've seen made bolt onto usally cross mebers and gear box mounts with counter sunk tapered bolts. This alieviates hook ups on bolt heads. As with all mods, the thicker the heavier. Shorter pieces to reach convenient place seem to be stronger than on larger long piece.
    Mine has been fabricated with two sheets of metal. the piece facing sump is flat with holes cut out for fluid and debri escape. the second which is welded to the first is basically ribbed I suppose the best way to explain it. with the same holes in it. The holes would also reduce some weight as the ribs produce the strength.
    Hope this helps
    WA Wheatbelt
    23 Post(s)
    Quote Originally Posted by Finly Owner View Post
    Hope this helps
    Thanks for the info Tim. From memory, ARB sell them, and they're red - and all u have to do is bolt them on. I may be wrong?
    Nasty Dog - Moderator Woof's Avatar
    Perth WA
    61 Post(s)
    I think what you are talking about Ross are dif protectors as they are red.
    If any members require assistance in anything regarding this forum, just let me know via a PM and I will help you in any way that I can.
    WA Wheatbelt
    23 Post(s)
    Quote Originally Posted by The Dogman View Post
    You're right - again - Wayne.
    I knew it was something underneath the driver's seat I was thinking about. Let's keep the thread going.
    I might learn some more. lolol
