Results 1 to 10 of 13
Thread: IC upgrade
    Dec 2016
    Yarrabah
    IC upgrade
    Hi
    I have a 2004 zd30 patrol . I'm chasing some advice as to what ic to buy . not rolling in cash atm .
    So something not over the top would be good .
    Thanks Craig
    Legendary 4bye4's Avatar
    Aug 2014
    Kingsley WA
    15 Post(s)
    I have had one of these for three years now with no issues. http://www.brownsradiators.com.au/sh...&id=CACNIS1024
    Reading here Cross Country seem to be popular as an upgrade, but if your stuck for cash a fully welded one should do the job, but make sure you are not getting a cheap and nasty.
    IMO I think the cross country against an OE tigged intercooler is not worth the money.
    Im talking bang for buck$$$, The CC IC will cost $1200 and up and if they are bothered to post
    it.
    A diesel Smart IC will cost about $350- $400 and have a similar outcome.
    My money was spent on the above IC and I love it,
    Make sure you get a pressure tested IC as well,tested to 60psi is ok
    Dec 2016
    Yarrabah
    Hi threedogs
    What you are saying sounds good ,are you running the standard scoop ?
    What boost etc are you running ?
    What is the turn around time for these ic's ?
    Quote Originally Posted by FNqGu04 View Post
    Hi threedogs
    Im running about 20psi boost maybe a tad more,
    Im also running an ARE scoop which I love.
    Turn around was good a few days not sure about
    this time of year.
    Runs great very happy with performance
  6. #6
    Hi threedogs
    Something like this one wont break the bank and
    pressure tested to 55 psi
    http://www.ebay.com.au/itm/TOP-MOUNT...wAAOSwJcZWejqp
    and this boost adaptor when you run a boost gauge
    http://www.ebay.com.au/itm/Patrol-ZD...4AAOSw5cNYLPmR
    If you're going to NADs your motor give @mudski a PM for
    some more info, he'll have what you need from a catch can
    to boost controller.
  7. #7
    Dec 2016
    Yarrabah
    Hi threedogs
    Would you believe I already had that IC saved in my watch list ,the same with the adapter .
    How much did the scoop cost and where from ? I have a mate who is a painter ,so that's all good as far as paint is concerned.
    I would have thought that kind of boost would have thrown a code .
    I'm running 315/75/16 tyres , we have a little "hill" near our place ,it's about 2km to the top . It is 18% to 20% for most of the way ,
    coming over in 3rd for most and 2nd for the steep bit I'm seeing 550 EGT at the most . Is that safe ?
    The IC is leaking a fair bit .
    Craig
  8. #8
    477 Post(s)
    If you IC is leaking this wont be helping your EGTs. The scoop that John and shown a pic of is from a mob called A.R.E. If you can work out their website. Its on there somewhere. Good luck. http://www.are.com.au/index.htm
  9. #9
    you can also get the scoop from Guest 4wd in Fairfield Vic.
    They are not cheap $400 plus
  10. #10
    Dec 2016
    Yarrabah
    Hi
    I got on the are website last nite ,scoop is about $600 I think .Also found a bit of info about what works and what doesn't .
    Had a dig around egay also and found an ic for $320 so it mite get the nod.
    Craig
