Results 1 to 8 of 8
Thread: Can you reset computer without disconnecting battery
    Dec 2016
    Yarrabah
    I have an 04 zd30 patrol usual mods ,doesn't want to rev over 2500 rpm .like its in limp mode .
    I have not heard of it being re set with out being disconnected.
    So disconnect clean the maf have a drink and re connect, Take it for a test
    drive, What boost are you achieving, if known ??
  3. The Following User Says Thank You to threedogs For This Useful Post:
    FNqGu04 (7th December 2016)
    Dec 2016
    Yarrabah
    Hi threedogs
    Im getting about 17-18 psi ,I have a HPD style boost controller and egr block off plate .
    Not sure if controller is set up right
    SUCH IS LIFE Maxhead's Avatar
    ACT
    could be your tps (throttle position sensor)???
    pull it out and spray some contact cleaner in there to see if it makes any difference
    ________________________
    ______ 2017 D-Max _______
  6. The Following User Says Thank You to Maxhead For This Useful Post:
    Dec 2016
    Yarrabah
    Did the battery disconnect as threedogs suggested ,went to clean the maf .
    I was messing around the other night n didn't reconnect it .
    Major rookie error ,would still like some help setting up HPD boost controller though .
    Thanks to all
    Im not familiar with the HPD controller maybe @mudski can help you
    Those boost controllers are like the Dawes and Tilix. Wind in for more boost and out for less. IF you are getting limp mode symptoms this may mean an over boost issue. But the cause can be a dud maf, incorrectly set controller, hole in the intercooler will also give poor performance.
    If its not revving whilst sitting there with no load i doubt its the intercooler or wrongly adjusted controller. A dud maf can do this, blocked fuel filter too. Block air cleaner????
    Bad fuel??? Possibly many other things too..
  10. #8
    SkippyGU JackCollo's Avatar
    Dec 2016
    Melbourne VIC for now
    Mine was doing that as well and I have a feeling it is the boost sensor on the intercooler. When I was driving home it felt like I was being held back. Took my foot off the throttle and accelerated again and it was fine. Try turning your boost down a bit and see how you go.
    Let us know
