Page 30 of 77 FirstFirst ... 2829303132 ... LastLast
Results 291 to 300 of 762
Thread: Jay see 1997 GU build up
  1. #291
    Expert Mike02Ti's Avatar
    Jun 2016
    Rockingham WA
    4 Post(s)
    Correct me if im wrong but dont both the Engel and Waeco both use a danfoss compressor now? Whereas before i think only Engel did
    2002 GUIII Ti 4.8
    Details here
  2. #292
  3. #293
    Quote Originally Posted by Mike02Ti View Post
    Nah, mate.
    No expert here, but being doing some (alot) reading and the Engel uses a sawafigi (Japan) and waeco used to use the danfoss, but now it's there own brand which is the danfoss assembled in China.
    I think .
  4. The Following User Says Thank You to jay see For This Useful Post:
    Mike02Ti (21st November 2016)
  5. #294
    Nah, mate.
    I think .
    Yes correct. The Sawafuji is a piston type compressor and the danfoss in a, rotational type?, compressor. If thats what you call it. Without googling it I think thats the differences between the two. I will say, the ARB fridge is almost dead silent, all I can hear is the fan running, where as the Engel I can clearly hear the compressor.
    jay see (21st November 2016)
  7. #295
    Both are piston style compressors.
    I'm actually not sure if ac systems use anything but piston.
    Similar to your car ac compressor.
    It's an off set (slanted) disc that drives pistons to compress the air..
    Come to think of it I think that's how deisel pumps work on our engines..
    Your right about the 2 being on even par..
    The weaco is silent as, but does use a little more power to drive the pump.
    The Engle is a bit louder but a bit less current draw..
    Those insulation covers help a lot imo..
    Worth the little extra coin.
  8. The Following User Says Thank You to BigRAWesty For This Useful Post:
    mudski (22nd November 2016)
  9. #296
    Need some confirmation on installing the Albright solenoid.
    There's different images online on how to install. One was like this.
    The other was with the yellow swapped over with the black.
    Which way is correct.
    Also the thin wire coming off the bottom of the winch motor, where dies that go.
    Thanks in advance.
  10. #297
    This is exactly how I've wired it up and nothing...... What have I done wrong?
    Electrical is not for me....
  11. #298
    22 Post(s)
    How have you wired your switch?
    96 GQ coil/Cab
    08 G6eT
  12. The Following User Says Thank You to Ben-e-boy For This Useful Post:
    jay see (27th November 2016)
  13. #299
    Yes. Wired handheld
    I cut off the original plugs and replaced with longer bladed ones.
    Have tested and has power.
    The twisted red wire is temporarily.
  14. #300
    22 Post(s)
    Yes. Wired handheld
    Why is there a temporary wire hanging off the earth.
    This is how it should be wired. The pic you posted earlier with the power in and power out description on the coils is incorrect. Probably more misleading.
    I dont understand why you have a temp cable hanging off the earth.
    96 GQ coil/Cab
    08 G6eT
  15. The Following User Says Thank You to Ben-e-boy For This Useful Post:
