Results 1 to 6 of 6
Thread: Gu patrol-xr6 turbo conversion
    Jul 2016
    4 Post(s)
    So after very long thinking, research and a lot of back and fourth with my performance centre, I have decided to go down the path of the XR6 TURBO over the well known LS conversion.
    Why?
    Well for me the decision was hard but in the end the answer for me was made by the follwing.
    1 BF 10/06 model XR6 TURBO engine ( from 06/06 onwards this model have the same bottom end as the typhoons with forged internals.
    Its a multivalve engine with low kays
    Dual VCt,
    Flat in line 6 that pretty much doesnt need to be opened.
    After a bit of research i have also been told that the xr6 turbo engines do not need much done to achieve decent kw and torque figures.
    Given i am looking at having a reliable 4wd i dont think i will be going stuoid with it but just to give you an example,
    Cooler, injectors, exhaust, up boost and a dyno will give you in excess of 300 rwkw.
    The LS was quickly put aside when i realise that in order for me to get it running nicely it would have required the engine to be opened up and start playing bits n bobs so in the end opted against it.
    Today i purchased my donor engine amd it basivally came with everything but the tranny, including cooler, aircon, thermo fans, start amd alternator ecu and both looms.
    Basically everything i need for the conversion.
    Now, from what i know i need to contact killer customs (i think thats what theyre called in qld) so that they can make me a custom loom to suit the original 4.5 litre petrol to xr6 turbo engine,
    I need custom engine mounts
    And bell housing.
    For those of you more mechanically minded than me what else do you thik i will need to get this done?
    If im missing something please let me know.
    Will keep you guys posted.
    MMM.
    A turbo whistle is nice, but you can't beat the rumble of an 8.
    That's just me tho.
    Good luck with it all and keep us posted on the progress.
    82 Post(s)
    Dunno about a GU, but this bloke converted a GQ. http://www.nissanpatrol.com.au/forum...ght=conversion
    If my old RB dies, this is the conversion I would seriously consider doing.
    Jul 2016
    4 Post(s)
    Cheers mate
    I have read that thread from start to finish
    Though i dont know if he frequents the site anymore as the last post was over a year ago?
    The barra turbo has been one of those patrol conversions tht are starting to come into the lime light as more and more people are starting to see there worth.
    I love the sound of a good old v8 but unfortunately the ls 1 is starting to get a little old for me.
    The second i end up with the engine it will be making its way over to my mechanics and will sit there untill i get the rest of the gear ready.
    So far all i know i need is custom loom (plug n play to 4.5 petrol)
    Bell housing
    Custom engine mounts.
    Aparently it is around the same.weight as the 4.5 so engineering wise should be relatively straight forward but we are still yet to here back from engineer
  5. #5
    Patrol Freak jff45's Avatar
    Morayfield, QLD
    Will it need much custom exhaust work done with the XR6 exhaust on the RH side? How close to the steering does it come?
    John
  6. #6
    Jul 2016
    4 Post(s)
    No idea john i shall keep you updated but if its my biggest problem i should be ok.
    More worried about the entire build with loom and bell housing fitting if anything then the auto 4.5 tranny will need strengthening to deal with the power.
