Hi, thanks for the add, I have a 2002 3lt Patrol that has a brand new battery but will not turn over fast enough to start any ideas? Thx
Has it just started doing it? Has it been getting worse or all of a sudden?
If it turned over it should start. The NATS (Nissan Anit THeft System) cuts off the fuel solenoid on teh back of the pump and it could be your problem.
Its a Nissan! =====> Its a Keeper!! ....... Got a TD42 in it BONUS!!....... I'm a lucky bugger! I've got 2 of em!
Welcome aboard Spook58 !
I'm sure someone with descent lecky advice will be along shortly to assist mate. My only guess would be solenoid thingy issues off your starter motor mate?
@Yendor might be able to guide you mate, I have experienced this on a TD42 but not a ZD30. Search the forum for NATS and or Immobiliser fault and you will find some info. When did you fit the battery?
Does it turn over slowly?
Welcome to the forum mate.
any luck on starting?
Hey mate, welcome to the forum.
1989 GQ TD42 N/A.
G'day and welcome mate. If its turning over slowly, it may be the starter nmotor atself or corrosion on the 12v main lead or terminal causing high resistance. After trying a couple of time, check the terminals at the starter motor end and the battery end and see if they are hot. that would indicate a high resistance joint.
