Page 1 of 3 123 LastLast
Results 1 to 10 of 24
Thread: Long range tank - breather line versus fill line
    Legendary dom14's Avatar
    38 Post(s)
    Hey Guys,
    I'm just wondering about the reason that in my long range tank(LRA automotive tank), the breather line & fill line
    is at the same level.
    This means, if I fill the tank to slightly above the fill line, the breather line will also get filled with petrol!
    How does that help as a "breather line"?!!!
    Shouldn't the breather line come out from the highest point of the tank(like the charcoal canister line level in the picture below)??!!
    Thanx
    P.S. I think it's also pretty bad design to put the breather line right next to fill line that close. It creates a fitting nightmare when it comes to access the hoses and hose clamps to them.
    Few more mods on the way
    https://www.panthera.org/
    Cheetah Outreach
    So the one next to the filler is a fast fill line. That's what allows the fuel to fill the tank without going back up the filler neck..
    The smaller one on top of the square is the low pressure breather.
    This allows for expansion and contraction of the fuel
  3. The Following User Says Thank You to BigRAWesty For This Useful Post:
    dom14 (7th November 2016)
    38 Post(s)
    Thanx mate.
    I'm beginning to understand the fuel system mechanics/physics now.
    Cheetah Outreach
  5. The Following User Says Thank You to dom14 For This Useful Post:
    BigRAWesty (7th November 2016)
    38 Post(s)
    I'm about to do a complete fuel system plumbing/breathing diagram of the RB30 fuel system with real pictures attached to it. It will come handy in future for everybody.
    Cheetah Outreach
  7. The Following User Says Thank You to dom14 For This Useful Post:
  8. #5
    38 Post(s)
    If I had time, I would've moved the "fast fill line" bit further away from the fill line(same level of course).
    It's a pretty bad design to make it that close to the fill line, I think, 'cos there's no obvious reason for it to be that close
    to the fill line, even though being at the same level as fill line makes sense.
    Cheetah Outreach
  9. #6
    That fast fill only returns to the top of the filler neck, just past the flow of the nozel. .
    So air can quickly get past the flow of the fuel..
    Once the hole is covered then the fuel comes back up the line and clicks off the pump.
    The slow breather I'm pretty sure is vented to atmosphere threw a tiny filter which is tucked up on top of the fillers..
  10. The Following User Says Thank You to BigRAWesty For This Useful Post:
  11. #7
    38 Post(s)
    "Slow Breather" is the charcoal canister line by the looks of it, 'cos there's no other line that vents to the air, not even from the metal pipe near the fill point on the body. There a one way valve( and possible a filter inside as well) on the charcoal canister line(right above the tank, where the hose joins the metal charcoal canister fuel line)
    Does that sound right?!!
    I've attached few pictures below.
    Cheetah Outreach
  12. #8
    38 Post(s)
    Yeah, I was wrong. Obviously closer the "fast fill line" to the fill line is, quicker the overfilling fuel enters the "quick fill line" to cut off the pump at the filling nozzle. I wish it's an inch more away from the fill line on the tank, 'cos it was an absolute bastard when it came to access it and fit the pipes properly and tighten them properly.
    Cheetah Outreach
  13. The Following User Says Thank You to dom14 For This Useful Post:
  14. #9
    Yes the breather is the charcoal canister line..
  15. The Following User Says Thank You to BigRAWesty For This Useful Post:
  16. #10
    38 Post(s)
    I'm wondering whether LRA has done a half hearted job on mine(some twenty five years ago).
    There's no "vent to atmosphere" hole/filter/valve from the tank or the fill line/quick fill line plumbing.
    Only valve is the black cylindrical one in the picture, which is on the charcoal canister line which comes out of the top of the "expansion tank" on the top of the tank.
    Cheetah Outreach
