Page 170 of 220 FirstFirst ... 168169170171172 ... LastLast
Results 1,691 to 1,700 of 2192
Thread: AB's new GQ is finally here
  1. #1691
    Why was that cover not supplied with the engine?
    I don't know... They must've forgotten when they took pump out. They have it there just gotta get it now.
  2. The Following User Says Thank You to AB For This Useful Post:
    Stropp (29th October 2016)
  3. #1692
    So close!!!
    Clutch done as well..
    Just need vac pump and gear cover plate!!!
  4. The Following User Says Thank You to AB For This Useful Post:
    gubigfish (29th October 2016)
  5. #1693
    22 Post(s)
    So close!!!
    Did any oil feed hose for the vac pump come with that motor?
    96 GQ coil/Cab
    08 G6eT
  6. #1694
    No mate but I've just blocked the feed for now and will just bolt your vac pump up for now simply to block that hole with no gear.
  7. #1695
    22 Post(s)
    Could you use the old oil line from your original setup,
    96 GQ coil/Cab
    08 G6eT
  8. #1696
    Nah the port is a long way from the pump. You can easily MacGyver something up though.
  9. #1697
    Never ending...lol
    Word from the wise is that the gear on the vac pump is pressed so I have to feed oil to it.
    Back to a pirtek Monday for another custom fitting.
    Just when you think you're sorted...
  10. #1698
    It's all great experience old mate, positive perception is the key to life ;-) !
    You'll be able to strip down a 4.2TD from hands on memory like the QLDers in the middle of nowhere after all this ;-) !
  11. The Following 3 Users Say Thank You to MB For This Useful Post:
    AB (29th October 2016), MudRunnerTD (29th October 2016), Stropp (31st October 2016)
  12. #1699
    Patrol Guru Sprock's Avatar
    Jun 2015
    Heyfield Vic
    35 Post(s)
    That's unreal !!! You learn something everyday , bugger me 😝
  13. #1700
    Jun 2015
    Heyfield Vic
    35 Post(s)
    And Auspost SHIT ME !!!! When we used to load Auspost out of Brisbane for Melb we had to overnight it or we would get deductions on the load payment , from (hazy ) memory anything over 19hrs penalties would start for each hr over . But now if i order parts & get delivery through them it takes 3-4 days so it seems it takes a long time for the courier to pick it up in Brisbane and take it to the depot and the same down this end 😤
