Page 28 of 35 FirstFirst ... 2627282930 ... LastLast
Results 271 to 280 of 341
Thread: Fund Raiser AB blew his engine
  1. #271
    North brissy
    Cheers mate, same crank as silver or were they td42t cranks?
    The ones I have had apart far enough to see have all had the larger spigot on the flywheel end. So more like the T engine.
  2. The Following User Says Thank You to nissannewby For This Useful Post:
    AB (11th October 2016)
  3. #272
    The pistons were lighter that was about it. Cranks seem to be the same and apart from little end differences rods arent any weaker. I put one together that ran 23psi and just over 200rwhp. it has done about 30,000km without issue.
    Little end differences in conrods?
  4. #273
    North brissy
    There are 28mm and 30mm gudgeon pins. So obviously the little end (piston end) will be different. This seems to be more of a disassemble to know. Although I think the silvertop maye have 28mm gudgeons and the blacktop and NA have 30mm gudgeons. Ben-e did note some of this is in his engine build thread Im pretty sure.
  5. The Following 3 Users Say Thank You to nissannewby For This Useful Post:
    AB (11th October 2016), BigRAWesty (11th October 2016), MudRunnerTD (11th October 2016)
  6. #274
    Patrol Guru Kimbo63's Avatar
    Dec 2015
    Perth WA
    5 Post(s)
  7. The Following 4 Users Say Thank You to Kimbo63 For This Useful Post:
    AB (12th October 2016), Rossco (12th October 2016), Sir Roofy (12th October 2016), Touses (12th October 2016)
  8. #275
    22 Post(s)
    The easiest was to tell a true silvertop block (if it is dismantled obviously) the ports for the lifters. Silvertops have 25mm lifters, NA blacktop and T have 27mm.
    My 96 blacktop had the 30mm gudgeons. The sludged pre Aug 95 blacktop I was offered for replacement of my POS pile of scrap was a silvertop with a black rocker cover. 28mm pins, 25mm lifters.
    The article above saying black tops are unsuitable for turboing is nothing but an opinion based on a guess.
    Yes. I did crack 3 pistons, 2,4 and 6. All originating from the centre of the swirl chamber, cracking perpendicular to the gudgeon pin. I cannot see the cracks on the under side of the crown. I haven't done a proper crack check though and likely wont. I'll add that I was turning a 30 psi boost gauge pretty much back around to zero,
    I didn't strip the motor because of the cracked pistons, it was always going to happen. I just was not surprised when I found them.
    96 GQ coil/Cab
    08 G6eT
  9. The Following 5 Users Say Thank You to Ben-e-boy For This Useful Post:
    AB (12th October 2016), gubigfish (12th October 2016), MB (12th October 2016), MudRunnerTD (12th October 2016), nissannewby (12th October 2016)
  10. #276
    Might have found something folks!!!
    I'll let you know tomorrow!
    Excitement!
  11. The Following 10 Users Say Thank You to AB For This Useful Post:
    Avo (12th October 2016), gubigfish (12th October 2016), jack (12th October 2016), jay see (12th October 2016), MB (12th October 2016), MudRunnerTD (12th October 2016), mudski (12th October 2016), Rossco (12th October 2016), Touses (13th October 2016), Woof (12th October 2016)
  12. #277
    Hardcore jack's Avatar
    Ballarat Area
    26 Post(s)
    Fingers crossed for you AB
    Jack
    2024 Isuzu MUX
  13. The Following User Says Thank You to jack For This Useful Post:
  14. #278
    SUCH IS LIFE Maxhead's Avatar
    ACT
    Excitement!
    Finally he converted to a 3L...lol.
    Dazz another in the bank
    ________________________
    ______ 2017 D-Max _______
  15. The Following 7 Users Say Thank You to Maxhead For This Useful Post:
    AB (12th October 2016), Avo (12th October 2016), BigRAWesty (13th October 2016), jack (12th October 2016), MudRunnerTD (12th October 2016), rusty_nail (14th October 2016), Woof (12th October 2016)
  16. #279
    Finally he converted to a 3L...lol. Dazz another in the bank
    Stop giving me money!!!!!!!!!
  17. The Following 2 Users Say Thank You to AB For This Useful Post:
  18. #280
    483 Post(s)
    Might have found something folks!!! I'll let you know tomorrow! Excitement!
    Please say you haven't pilfered the Chev in my absence, jealousy is a curse ;-)
