Page 12 of 12 FirstFirst ... 101112
Results 111 to 112 of 112
Thread: Clutch woes.
  1. #111
    Failing harmonc balancers cause vibration,if they cant dampen it, those vibrations have to go somwhere, you've done everything else and at 'wits end' with it all.
    I had a look at the harmonic balancer this morning and again this afternoon when it was warm, not too sure what I should be looking for though.
    It doesn't wobble and is tight on there, doesn't make any noises when it spins either.
  2. #112
    22 Post(s)
    Its the rubber in the balancer itself it can degrade and become brittle, it won't do its job properly if that happens
    It need to come off to check
    96 GQ coil/Cab
    08 G6eT
