Page 89 of 101 FirstFirst ... 8788899091 ... LastLast
Results 881 to 890 of 1003
Thread: Hodge's new 4.2
  1. #881
    177 Post(s)
    I'm not sure welding would add much benefit. But then again I'm no structural engineer. Everything fit perfectly and snug, so I think it is adequately doing the job it's designed for. I can see how the factory tower hats crack, the metal meat up there isn't enough in my books.
    Took me good 2-3 hours. Longest part was getting the coils out for me.
  2. The Following 5 Users Say Thank You to Hodge For This Useful Post:
    BigRAWesty (27th August 2016), jay see (27th August 2016), Kimbo63 (28th August 2016), sooty_10 (27th August 2016), Stropp (27th August 2016)
  3. #882
    Aug 2016
    Portland, ME 04101
    It still looks new.. how much did you get this again?
  4. #883
    Did the clutch resolve your noise issue hodge?
  5. The Following User Says Thank You to nissannewby For This Useful Post:
    Hodge (8th September 2016)
  6. #884
    177 Post(s)
    Hey Mat long time no hear hope all is well.
    Clutch hasn't been done yet. Had few issues pop up postponing it.
    But in saying that, that noise has gotten considerably worse. It's now borderline embarrassing to drive. Forget the loud straight through exhaust, it's the rattling noise that turns heads now days.
  7. #885
    177 Post(s)
    Bumped into another 4.2 owner at a servo and had chat before.
    He noticed the way my car starts and he says it's not right.
    Basically, when starting, my car does not crank at all. I wait till glow light is out, and the second i turn the key, and electrics make contact, it just fires up. I mean the motor maybe has half a turn at most and she just starts. It has always been like this.
    He says that it's because the pump and injectors lines retain too much pressure when car is off, and this is not good ???? It's meant to return the remaining pressurized diesel in the lines back through a spill valve?
    His car was same as mine, series 4 4.2 2006. And his cranks for one or 2 seconds and then rumbles to life.
    My car has been like this since day one of owning it so, I don't know.
    I'm not concerned. But just curious, what's your thoughts Mat ? @nissannewby
  8. #886
    476 Post(s)
    It starts instantly. Whats the issue with that? It would be more concerning if it was the other way I think. Atleast you have a 4.2 you can start...
  9. #887
    177 Post(s)
    It starts instantly. Whats the issue with that? It would be more concerning if it was the other way I think. At least you have a 4.2 you can start...
    I thought so too, but just curious. This bloke could have been on the spicy smokes for all I know.
    I'm no expert but the way I see it. Mechanical pump should produce no pressure when the car isn't running? So what pressure in the system lol.
  10. #888
    Thats how all my tds start.
    Straight away no hesitation. If it doesnt start like this something is up.
    @Hodge
  11. The Following User Says Thank You to nissannewby For This Useful Post:
  12. #889
    Perth WA
    63 Post(s)
    Mine is exactly like yours mate, maybe his has the problem
  13. #890
    Mine is a gas blower and I start it up a couple times a day.😜
    Sent from my XT1068 using Tapatalk
