Page 151 of 220 FirstFirst ... 149150151152153 ... LastLast
Results 1,501 to 1,510 of 2192
Thread: AB's new GQ is finally here
  1. #1501
    Yeah wow this is interesting. As we were so sure it was just the turbo at fault. We can only hope the the smaller oil drain diameter is restricting flow causing it pressurise internally and leak past the seal.
    Not sure if this is of any help, or you have already done this but heres a few links for you. There might be some things here you might not have checked????
    http://www.turbos.bwauto.com/product...eshooting.aspx
    http://turbolabofamerica.com/causes-...burn-oil-find/
    http://www.full-race.com/catalog_ima...leshooting.pdf
    AB (5th September 2016)
  3. #1502
    All that and then some. Videos were supplied to us for tests that arent on any of those lists.
  4. #1503
    Yeah wow this is interesting. As we were so sure it was just the turbo at fault. We can only hope the the smaller oil drain diameter is restricting flow causing it pressurise internally and leak past the seal. Not sure if this is of any help, or you have already done this but heres a few links for you. There might be some things here you might not have checked???? http://www.turbos.bwauto.com/product...eshooting.aspx http://turbolabofamerica.com/causes-...burn-oil-find/ http://www.full-race.com/catalog_ima...leshooting.pdf
    Thanks mate but trust me, Google had to put on some extra servers in the last month with me!!!
    I'll hopefully have an answer very soon!
  5. The Following 2 Users Say Thank You to AB For This Useful Post:
    Rossco (5th September 2016), Stropp (6th September 2016)
  6. #1504
    Well some good news finally!
    Came up with an idea to have no oil drain or fitting on at all and simply have the oil draining from the turbo into a funnel into the sump.
    This eliminates every possible issue from the engine side, oil fittings, draining etc and it enables me to run the engine for as long as I like to ensure all residue oil already inside the compressor is exhausted from previous tests.
    Confirming again my oil pressure and oil flow is spot on!
    After 30 minutes of running and even revving the engine the leak became noticeably worse which was a relief to me as I became completely lost in what to do after every previous check was fine.
    There is some underlying issue with this turbo that needs the pros to work out so I'm happy to say a new one is on its way.
  7. The Following 12 Users Say Thank You to AB For This Useful Post:
    Chappy (19th September 2016), Clunk (13th September 2016), gubigfish (13th September 2016), jack (13th September 2016), jay see (13th September 2016), Kimbo63 (13th September 2016), Rossco (13th September 2016), Sherro (13th September 2016), Stropp (14th September 2016), timbar (13th September 2016), Winnie (13th September 2016), Woof (13th September 2016)
  8. #1505
    Awesome result at last!
    Can't believe the ordeal you have had to go through here. Crazy man! I am glad you didn't let it break you though, I think a lot of people would have given up.
  9. The Following User Says Thank You to Winnie For This Useful Post:
    AB (13th September 2016)
  10. #1506
    Getting there mate, slowly but surely..
    Sent from my XT1068 using Tapatalk
  11. The Following User Says Thank You to jay see For This Useful Post:
  12. #1507
    Awesome result at last! Can't believe the ordeal you have had to go through here. Crazy man! I am glad you didn't let it break you though, I think a lot of people would have given up.
    It did break me mate. I will now spend the rest of my driving days checking oil level every single time I drive this thing...lol
  13. The Following 2 Users Say Thank You to AB For This Useful Post:
    growler2058 (24th September 2016), threedogs (25th September 2016)
  14. #1508
    Happy days man! Top stuff!
  15. The Following User Says Thank You to mudski For This Useful Post:
    AB (14th September 2016)
  16. #1509
    Yeah nice one. Hopefully get the beast going soon and can enjoy the thing, is been a while did well to persevere but spose you leant a fair bit if there's a positive.
  17. The Following User Says Thank You to Rossco For This Useful Post:
  18. #1510
    Ha. Funny that.
    Once you have a major ish problem it's sticks with ya.
    My eye is always on the temp gauge, thanks to the issues I had with the oyta I had.
  19. The Following User Says Thank You to jay see For This Useful Post:
