Page 4 of 5 FirstFirst ... 2345 LastLast
Results 31 to 40 of 47
Thread: To much boost
  1. #31
    When the engine is off the vnt arm on the turbo will down..
    Then when you start the engine it'll lift..
    It's how the vacume vnt turbo works..
    The reason for hearing the leak is you know the factory snail can make 25 psi. .
    His dawes is right in so max boost. Still only making 13 psi..
    That's one hell of a leak..
    Yeah still, depending on where the leak is too. My original IC in my ol'ZD was leaking and I couldn't hear it....
    Email answered Phil....
  3. #33
    Oct 2015
    Sydney
    If the arm doent go up or down with engine on or off whats that mean?
  4. #34
    Quote Originally Posted by Rex13 View Post
    Vac leak, stuffed vac pump or possibly shot turbo vains..
    Take the actuator off and see if the turbo vnt arm moves freely..
    If not new turbo..
    Oct 2015
    Sydney
    When i take the vac hose off the actuator there is suction on the hose.
    Could the actuator be stuffed?
  6. #36
    I think your looking to hard into this right now. Test the IC first for leaks. Then worry about the next step.
  7. #37
    Oct 2015
    Sydney
    How do i test ic?
    Does a radiator repair shop do this?
    Sorry for all the question, just want it fix, im sopose to be going away in 3 weeks.
    QUOTE=mudski;693295]I think your looking to hard into this right now. Test the IC first for leaks. Then worry about the next step.[/QUOTE]
  8. #38
    Seal both end of the ic up with duct tape or the same. Then submerse the ic in water with the inlet and outlet above the water, then use a bike pump with one of those ball pump needle thingo's and push it through the tape and pump air into the ic. If you see bubbles then its leaking. Or just take it to a radiator mob....
    You need to do one thing at a time otherwise you will just get lost in it all. Make sure the ic is good then move onto the next thing. Resetting the dawes and needle valves.
  9. #39
    Oct 2015
    Sydney
    Sweet, thanks.
    I cant do till friday, i let ya all know how i go.
  10. #40
    Oct 2015
    Sydney
    Havent had chance to do anything yet, but i did do a test
    100kph
    3200 rpm
    6 psi boost
    420 egt
    3rd gear (auto)
    Does this sound right?
