			Ive looked at pricing for intercooler upgrades
Hpdiesel with fan $1295
Crosscountry with fan 1595
Anyone use these?
				Dont waste your coin. The ZD is no power house mate. You wont see enough return for $$$. I was using a cheap $400 IC and running 25psi no issues. Put the money into a better scoop. The OEM scoops are just too low and dont catch enough air.
BigRAWesty (24th August 2016)
				If you've got dawes right in surely you can hear the boost leak..
That thing woukd be humming..
If you can't hear the turbo or the squeal from the leak I'd be looking for a vacume leak on your actuator system..
When you start the car the turbo arm should lift straight up to the adjuster screw..
				Dont go spending big $$$ on your IC as Mudski says its no power house, as quick as they are.
Things like a larger IC are a total waste of money,,money which could be spent elsewhere.
$500 should see you with a quality IC
Heres one for you tested to 60psi with 2 yrs warranty
http://www.ebay.com.au/itm/LARGE-INT...QAAOSwhcJWIJfp
			Ive never seen the actuator rod move. Open and close the needle valve with motor idling and it doesnt move.
Cant hear any leaks.
QUOTE=bigguwesty;693237]If you've got dawes right in surely you can hear the boost leak..
When you start the car the turbo arm should lift straight up to the adjuster screw..[/QUOTE]
				You wont always hear a boost leak, its only 16 or so psi, plus with the engine noise going on it would be hard to hear.
To the op, test the intercooler first, then start from scratch with the dawes and needle valve setup. Otherwise you will just get yourself confused.
			Hi Mark, i just sent you an email, do you have spare springs for the dawes valve, mine seemed a bit out of shape when i looked at it yesterday.
Phil
QUOTE=mudski;693255]You wont always hear a boost leak, its only 16 or so psi, plus with the engine noise going on it would be hard to hear.
To the op, test the intercooler first, then start from scratch with the dawes and needle valve setup. Otherwise you will just get yourself confused.[/QUOTE]
